351w or 302 ?????
351w or 302 ?????
My Ford book says, "The quickest way to block identification is the casting number and date code found above the starter on the righthand side of the block...." It should read something like: D4AE-6015-AA-10. The codes are as follows:
D10E-AA 302 '70-'74
D1TE-AA 302 '71-'74 Truck block
D4DE-AA 302 '74
D5ZY-AA 302 '75-'81
D2AE-BA 351W '71-'74
D4AE-AA 351W '71-'74
D4AE-DA 351W '75-'81
So the above block mentioned in the text is a '75-'81 351W. I don't see anything mentioned about a change in the oil pans and it looks like they should interchange.
'82 F150 2WD w/351W (orig 300 I6)
Slik
D10E-AA 302 '70-'74
D4DE-AA 302 '74
D5ZY-AA 302 '75-'81
Slik
351w or 302 ?????
Your missing the first 2 letters which would give you the decade of the block and I don't see anything with an ED, but I do show the following:
D2AE-6015-EA is a 351C HO manufactured between '71-'74 with a 4-bolt main.
D2AE-6015-DA which is a 351C with a 2-bolt main manufactured from '72-'74
I'm guessing someone dropped in a 351C HO and you've got a real live rare monstor on your hands.
The HO 351C had upwards of 310 HP and could be running as high as 10.5:1 compression.
Slik
Slik
351w or 302 ?????
Tom,
So much for the book!! I checked my block and it was listed as D9AE-6015-ED. Mine is a re-manufactured 351W and I measured the pan. It has 6" centers on the bolts on the back end where the deep sump is. Now I really don't know what to tell you.
Slik
Slik
351w or 302 ?????
351's have a support cast in by the distributor hole, 302's don't. As you stare at the front of the engine, it's a triangular support that goes from the intake mating surface down to the machined surface for the distributor. Kind of tough to tell unless you have a 302 and 351 sitting side by side but thought it may help.
