Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 06:38 PM
jb65542 is starting off with a positive reputation.
1970 f100
hi, i have a 1970 f100 4x4 with a 302 out of a 96 ford explorer and have a zf transmission behind it. i was wondering what the best way to add power to the motor. it is an all stock motor still fuel injected. thanks for any info
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 07:37 PM
rhetor is starting off with a positive reputation.
best way to add power is heads.
__________________
1995 F-150 reg cab long bed DECEASED
I6 300-M5OD-4.10 LS
33x10.5 BFG M/T mild head work, torque cam, 2.5" exhaust, roller rockers, 19lb injectors
New truck- 1971 F-100 2wd 302/c4!
  #3 (permalink)
Old 05-11-2008, 09:07 PM
what heads do you recommend. i already have gt40 that was stock with the explorer.
  #4 (permalink)
Old 05-12-2008, 06:06 AM
well, I guess we should take a step back.
What rear end gears do you have, and what are your RPMs at cruise on the highway?
How much are you looking to spend, and how much more power do you want?
__________________
I6 300-M5OD-4.10 LS
  #5 (permalink)
Old 05-12-2008, 06:03 PM
i have 3.55 gears in it and it runs 1900 rpms at 65. i just want it to keep speed when i go up a hill.
  #6 (permalink)
Old 05-13-2008, 06:04 AM
jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.jowilker has a very good reputation on FTE.
The engine may be running under it's power band. The simplest thing to try would be to go to a 3.75 rear gear.
Don't forget to change your speedo gear to keep speedo on target when changing ratios. Usually a change like 3.5 to 3.75 will be one tooth difference.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #7 (permalink)
Old 05-14-2008, 08:00 PM
I would agree. Changing to a higher ratio rear end would help you out a lot.
Long tube headers would help with low end power, but in the north east where i'm from, they rust real quick. They are also loud in the cab and i hate them.
__________________
I6 300-M5OD-4.10 LS
  #8 (permalink)
Old 05-14-2008, 08:04 PM
Dave Severson is gaining momentum as a positive member of FTE.
Procharger blower!!!! Great power and excellent driveability.
__________________
Anybody can restore a classic, takes a man to cut one up......
  #9 (permalink)
Old 05-15-2008, 08:46 PM
what rpm would i be running if i changed to 3.75 gears and are there any bolt on part that would help any at all
  #10 (permalink)
Old 05-16-2008, 05:08 AM
Check this site out * * Automotive Programs by Bowling & Grippo * *
Once you have your knowns you should be able to get your answer.
If your truck has a 9" rear it is just a matter of swapping the center section.
John
__________________
  #11 (permalink)
Old 05-16-2008, 11:15 AM
qman is starting off with a positive reputation.
What is it about new heads that would add power? How much different is it from changing from 2bbl to 4bbl carb?
__________________
92 F150 2wd 300 I6
72 F100 2WD 360 C6 PS
  #12 (permalink)
Old 05-16-2008, 11:25 AM
mcdobson is starting off with a positive reputation.
Be careful with the fuel injection. Any time you start changing things with EFI you run the risk of having the ECM not functioning properly. Check with the 5.0 EFI boys on the engine forum, they may have some advise for you.
Good luck.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
