Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 04:44 PM
bobquin is starting off with a positive reputation.
97 F350 Concern
Hi there ,
I started to notice yesterday that when I shift from drive to reverse or reverse to drive the trans would make a loud clunk ,,though other times it would go in with no noise. I looked underneath and found some transmission fluid from the drive shaft to the extension housing ( I think that is correct ? ) As i spin the shaft I can see som fluid around the gasket ...any info on what needs to be done woudl be great !
Thanks in advacne ,
Bob B
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 06:02 PM
Also I had the rear main seal replaced last week.... the transmission was taken out ...could that have any bearing on this ?
  #3 (permalink)
Old 05-12-2008, 06:44 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Rear main seal replacement would require r & r of the trans. A major fubar in the reinstall would be more than a clunk. Your rear trans seal is leaking, possibly the result of just age or some other issue. You got a trusted auto trans shop available? The rear seal on the trans is pretty easy, they can check other stuff at the same time.
  #4 (permalink)
Old 05-12-2008, 07:25 PM
Thanks for the response ...prior to the the work on the rear seal there was no vibration nor clunk when going into other gears ...can i drive it the way it is ?
  #5 (permalink)
Old 05-12-2008, 10:14 PM
sclariat is starting off with a positive reputation.
sounds like a bad u-joint. If it is a bad u-joint, it's probably also what tore the extension housing seal.
  #6 (permalink)
Old 05-13-2008, 07:21 PM
Thanks for the response....I'm feeling the same on this ! my guess is the way it the transmission was put or back or the drive shaft was installed as it had no issues prior . Thanks again .
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
