2004+ stake pocket templates- cut thru cap - Ford Truck Enthusiasts Forums
Old 05-11-2008, 03:15 PM
Truck2Board Truck2Board is offline
Truck2Board is starting off with a positive reputation.
Anyone know a good template for cutting the plastic cap to access the stake pockets?
If not, will try the dealer...
Also - anyone with experience placing stuff in the '04+'s pockets - Expect them to be hurky enough for just about anything, but can't find anything here...
Thanks!
Old 05-11-2008, 04:20 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
The caps pop right off, so when I had to cut mine for my bed rails, I just popped them off and made the cuts. Can't remember, but I seem to recall a slight outline from the underside. You could also get a trim bit and just cut the holes in place if you have some thing like that.
Old 05-11-2008, 06:32 PM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
pry the bed caps off, then apply some axle grease to the top of the bed around each bed stake. put the bed cap back on. remove
you should have a fairly perfect outline of the stake pocket
Is there something special about these stake pockets? dadgonebroke 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 01-06-2017 02:02 PM
2016 F-150 crew cab stake posts location Live4darumble 2015+ F150 5 07-24-2016 01:55 PM
Stake pockets needed moose79 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 01-12-2016 09:41 PM
Doses anyone make a stake pocket plug or cover. Skalywag 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-03-2015 11:02 AM
Rips and cracks around bed stake pockets greythorn3 Paint & Bodywork 1 03-02-2008 07:22 AM
Tags
2004, 2005, bed, cover, covers, cut, f150, f250, ford, hole, pocket, pockets, rail, removing, stake, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
