Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 03:05 PM
Buckmaster008 is starting off with a positive reputation.
Arrow '96 F-150 Programmers
I have a 1996 F-150 351 5.8 V8, I'm putting bigger tires and different gears on, and was wondering does anyone know if they make a programmer for this model and engine? Any info will be much appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 07:01 PM
ReAX's Avatar
Bleep Bloop
ReAX is gaining momentum as a positive member of FTE.
Your OBD II so your in pretty good shape, however Hypertech probably will not account for gear/tire changes. You should look at Superchips, Sniper, and SCT. I prefer Sniper after playing with them and Superchips.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
  #3 (permalink)
Old 05-13-2008, 04:27 PM
FTE Sponsor
Groovy Chick is starting off with a positive reputation.
Quote:
Hi there,
Just wanted to let you know that Power Hungry Performance has two options for your vehicle: a handheld programmer or a 4-position chip. If you're interested, please take a look at our website.
Blessings,
Corey
  #4 (permalink)
Old 05-13-2008, 09:11 PM
Thanks, I will.
  #5 (permalink)
Old 05-15-2008, 11:25 AM
Maxx_Mugsley is starting off with a positive reputation.
Quote:
Originally Posted by Groovy Chick View Post
Hi there,
Blessings,
Corey
They make some good stuff.
  #6 (permalink)
Old 07-13-2008, 08:35 AM
rossijd's Avatar
rossijd is starting off with a positive reputation.
I am wanting to swap gears and go with slightly larger tire on my 2wd,96,302. Bought a Jet Performance Programmer from Summit, but it didn't work. First one would not do anything when plugged into diagnostic port. Called Jet teck support, they were very rude and not very helpfull. So, I called summit and they said they would exchange it. The second one, when plugged in, told me "software needs update". Called Jet again and they told me to take my truck to a dealer and have latest updates downloaded to my PCM. I did. Cost $72. Plugged up programmer, got same error code! I am returning to summit for refund.
  #7 (permalink)
Old 07-13-2008, 12:08 PM
ReAX's Avatar
Bleep Bloop
I am not a big fan of Jet either. You have plenty of options, but be aware alot of the offerings for the earily OBD2 will not do all of the features. Hypertech used to miss the VSS, so they didn't allow for tire and gear changes. If the newer versions cover back that far, you have a good chance of being able to program, but if your looking at PP3s I wouldn't expect it. I've had pretty good luck with superchips max-tuners, I would think cortex and flashpaqs would be able to do tire/gear changes as well.
__________________
-MECP 06/27/08
  #8 (permalink)
Old 07-13-2008, 08:49 PM
rossijd's Avatar
Ya, I'm glad summit is working with me, otherwise I'd be out $350 and stuck with somthing I can't use. I called Hypertech and they don't have anything to adjust speedo on anything older than 99. I was concerned about swapping to 4.10 gears. Others on this site have told me that won't affect the speedo, so I really don't need the programmer anyway. I did talk to a tech at FRPP and he said within the next 2-3 months Ford was going to come out with somthing that plugs to the trans wire harness to adjust for tire size changes on the "older" trucks.
  #9 (permalink)
Old 07-16-2008, 09:12 PM
baldboyford is starting off with a positive reputation.
I have a 96 F150 that was a 5.0 and I swapped in a 351W stroked to 393. Found a local SCT dealer for an SCT Xcal2 to modify the ECM programming to accept the increase in cubic inches and general increase in performance. Not positive about gear changes and tire size changes, but I would think it would be able to do what you need. A Dealer may need to download a custom tune for it instead of being user adjustable.
__________________
Baldboyford
97 EB Explorer 5.0 AWD
96 F150 XLT Ext Cab 393 4R70W 4X4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
