Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 02:24 PM
masta-g is starting off with a positive reputation.
timing marks
hello all,
I have a 78 f-150 and recently changed out the motor blew the other one .i went to a newer motor from a salvage yard but now i have no power climbing the hills .what is the correct timing and there are marks in 3 different places on the front cover.my old mother would climb the 8% grade into town at 60 + this one will barely maintain 45 any suggestions??
masta-g
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 02:38 PM
OldMetal's Avatar
OldMetal is starting off with a positive reputation.
Knowing what year and size engine would help
__________________
77 F150 4X4
  #3 (permalink)
Old 05-12-2008, 09:49 AM
timing marks
it is a 1978 f-150 w/300-6 I pull a trailer some of the time and need to have at least as much hp as I had befor the engien swap
thanks for the reply
masta-g
  #4 (permalink)
Old 05-12-2008, 10:46 AM
Ford_Six's Avatar
Ford_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to beholdFord_Six is a splendid one to behold
WHat year engine did you put in? They dropped the compression quite a bit on the later engines before EFI, and also had retarded cam timing.
You should start at about 8ºBTDC on the timing pointer (not cast timing cover marks) at about 650rpm.
__________________
Jared
Quote:
Originally Posted by Tadao Ando
"If you give people nothingness, they can ponder what can be achieved from that nothingness."
FTE Guidelines
  #5 (permalink)
Old 05-12-2008, 07:42 PM
OldMetal's Avatar
For my 77 300 the timing is 10 degrees.
__________________
77 F150 4X4
  #6 (permalink)
Old 05-13-2008, 02:39 PM
thunderb's Avatar
thunderb is starting off with a positive reputation.
My timing marks on on the passenger side of the timing cover. You will see the toothed timing indicator on the cover over the balancer. There are also several lines on the balancer, use the thin scribe line. Clean and mark the timing marks before setting timing to make everything easier to see. i put a small mark on the 8 deg point as a reference. I run the stock 8 deg timing in my manual tranny truck. Any more and it likes to ping under load.
__________________
79 F-100 Custom
Big Block six
Hurst Mastershift 3speed floor shift conversion
Holley 390 4V, Offy intake, EFI manifolds, Chebbie rockers
Summit Racing 3.50 gearset
97 T-Bird Sport
Pre-SCT chip
Dynomax catback,
K&N
Tokico Advanced Handling kit (1.5" drop)
  #7 (permalink)
Old 05-18-2008, 10:12 AM
is there a place i can go online to decode the casting marks on the block to get compression ratio and what cam is in there
  #8 (permalink)
Old 05-18-2008, 11:53 AM
flipklos is starting off with a positive reputation.
8.0 or 8.8 depending on year
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
