Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 01:33 PM
Oregonwolf is starting off with a positive reputation.
Torque Converter Question
OK, Bronco Guru's, I am finally getting ready to put my new motor and transmission back in after draining the Transmission, including the Torque Converter. My question is there any special thing I need to do when I fill up the transmissions? Will it fill up the Torque Converter on its own? Or do I need to fill up the Torque Converter separately?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 03:01 PM
NWBronco is starting off with a positive reputation.
Less wear on the pump if you fill the converter. Also, not as much burping on the system.
  #3 (permalink)
Old 05-11-2008, 03:28 PM
b4hntn is starting off with a positive reputation.
You did not say what transmission so here is my experience.... On my E4OD I added about 6 qts to transmission then ran engine only about a half a minute. Repeated and shifted gears this time. Then 3 qts and drove it thirty minutes to check level. Added 1 qt. Be sure to use ATF fluid specified on dipstick. 16 qts for mine. Transmission fills torque converter.
__________________
If your ignition control module is a black Motorcraft (CCD system) do not replace it with a gray one. No disrespect intended, just my personal nightmare.
FTE is great! Be a supporter to keep this forum going. 94 5.8 EB, 460 air inlet tube, K & N drop in, MSD Blaster, 9 mm Ford Racing Wires, mechanical oil and temp guages and the rest all stock.
  #4 (permalink)
Old 05-12-2008, 08:33 PM
twisted limb is starting off with a positive reputation.
I was told buy a quy that use to rebuild trann'y to fill TC 1/2 way when installing.His words not mine.
  #5 (permalink)
Old 05-12-2008, 09:18 PM
Go with the experts. I only replaced the fluid.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
