1999 F150 Theft light blinks and engine dies - Ford Truck Enthusiasts Forums
Old 05-11-2008, 12:54 PM
monktana monktana is offline
monktana is starting off with a positive reputation.
My amazing 1999 F150 4.8 V8 2WD ExtraCab with 235000 miles.
Runs smooth as a sewing machine.
The truck just started with this issue
driving normal at any speed
the engine dies suddenly
the theft light is blinking
will not restart
Once this happened when my battery was dead and had to be replaced.
Replacing the battery solved the issue.
The battery is 12 months old and turns over the engine with lights on (as a test of the battery)
Today the truck would not start and the Theft light was blinking.
Just a few minutes ago the truck did start but the Theft light is still on and blinking.......
Any assistance resolving this issue would be greatly appreciated.
Billy in Pittsboro
Old 05-11-2008, 03:46 PM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
Im not too familiar with the theft system, but did you drop your keys into water?(if it has a PATS key) Someone who is more familar with the antitheft system should be here soon, to help remedy your problem.
Also i wasnt aware of ford making a 4.8l V8.... anyways welcome to FTE .
Old 05-11-2008, 05:46 PM
oops........ 4.6 V8
Thanks for the reply:
Yes, I have the........ 4.6 V8........
I do have the PATS computer chip key system.
It has not been soaked in water but we have had lots of rain.. that is nothing new so not sure why it would cause a problem now....
I look forward to getting my issue resolved.
Thanks, I appreciate the assistance!
Billy
Old 05-11-2008, 05:55 PM
Bobby82490's Avatar
I wonder if the anti theft device, is controlled by the GEM module?
Some of these trucks came with a faulty windshield seal.. which in some cases gets the GEM module wet, then certain thing start to go crazy.
Theft light blinking no start Hossfly05 6.0L Power Stroke Diesel 3 07-03-2015 05:06 PM
2002 F-150 XLT 4.6L. Fast blinking theft light RandyJ2007 1997 - 2003 F150 30 05-18-2015 11:41 AM
PATS issue? Truck won't start after changing plugs and COPS smashclash 1997 - 2003 F150 45 09-17-2014 03:17 PM
PATS Anti-theft problem on 1999 F150? denzelnuke 1997 - 2003 F150 3 12-15-2013 02:04 PM
Truck Won't Start: Theft Light Blinking, Fuel Pump Relay... SeannyBoy84 Modular V8 (4.6L, 5.4L) 2 07-01-2009 09:31 PM
Tags
150, 1999, blinks, died, engine, f150, light, stalls, theft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
