Engine swap in a 95 F150 4x4 - Ford Truck Enthusiasts Forums
Old 07-08-2000, 10:40 AM
windsor windsor is offline
windsor is starting off with a positive reputation.
Has anybody swapped out a 5.0 for 5.8?? I want more power and I know a gear change would help but I could do a engine swap faster. Truck is a daily driver and I want to know want changes had to be made ie..injector and sensor harness etc.. Any advice would be appreciated. Thanks Ford Fans Windsor660
Old 07-13-2000, 02:20 AM
claybo claybo is offline
claybo is starting off with a positive reputation.
The best thing to do is purchase a complete 351W engine out of another truck with low miles w/all
the brackets,pulleys,intake,etc.If you can't find
one w/low miles then just get one and rebuild it.
The 351W should fit right in place of the 302.You
might have to make some adjustments on your exhaust where the pipes connect.Also try it with
your existing computer.You may have to change it
out to one for the 351W.One more thing your gas
mileage will suffer as in 2-3 MPG less.I have a
93 and at the present time I'm changing the gear
from a 3.55 to a 4.10 to accomidate my 32" tires.
Old 07-13-2000, 07:48 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
I don't think the 5.0 computer would work on a 5.8 engine, unless you replace the distributor with a 5.0 one. I don't know if that is even possible. The tranny should also bolt up fine. If you have the smaller radiator, you might want to replace it with a larger unit. Otherwise, it should be a easy swap. My guess is also around 3-4mpg less than the 302, but you'll have a bit more highend than the 302 would have.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
Old 07-14-2000, 04:44 PM
donsboy donsboy is offline
donsboy is starting off with a positive reputation.
F150 auto trans Windsor to F250 manual trans windsor bobbyray1963 1987 - 1996 F150 & Larger F-Series Trucks 1 02-02-2015 09:12 PM
Windsor swap. Evans88 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 12-22-2014 08:02 PM
1994 4.9 to windsor swap RiverReaper 1987 - 1996 F150 & Larger F-Series Trucks 4 11-18-2014 05:16 PM
i bought a 1978 f 150 ranger 4x4 4 speed smalls7676 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-22-2014 12:22 AM
1997 Windsor to 5.4 conversion Showtruck 1997 - 2003 F150 3 12-29-2008 12:33 AM
Tags
4x4, 5058, 95, engine, f150, swaps, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
