Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 09:08 AM
mjbrown65 is starting off with a positive reputation.
newbie really bummin...
hi folks,
i am new to your forum and really hoping you can help me out... i have a 98 F150 STX 2wd with the 4.2 V6.the truck has 120,000 miles, never been beat on as the tires will show(owned it for 5 yrs and never put new tires, just rotate) and always changed the oil every 2500 miles.
this past week, i came out of work,and when i tried to start the truck, it locked up like the starter was stuck. i tried a few more times and a co worker tapped the starter with a hammer and the truck started and i drove home. when i got home i shut the truck off and re started several times with no troubles.
the next morning, i was going to work, and the truck did the sme thing with an added twist...when it finally fired, it made a huge bang, and vibrated the whole truck, and sounded like the motor was turning inside out. when i went out to see what the heck happened, all the oil was running out underneath.
i got under as far as i could and looked around , but couldnt see anything sticking out that wasnt supposed to be ( rods), and no holes that were not supposed to be there. just oil EVERYWHERE.
one guy at work thinks it may have jumped or blown the timing gear/chain,and another just says the motor is toast. can someone help me ? i am really baffeled , and extremly bummed. i love the truck, and just paid it off 6 months ago.
this all happened out of the blue with no warning. there was no knocks or strange noises coming from the motor.
thanx for time,
mike
  #2 (permalink)
Old 05-11-2008, 09:14 AM
Bobby82490 is starting off with a positive reputation.
The 4.2s are notorious for leaking headgaskets, which can fill the cylinder up with coolant. Are you sure there isnt any holes in the block?
__________________
-1998 F-150 5.4l auto 2wd, with a worn out 3.55 LS
-219,000+ miles w/ all orig. drivetrain
-No Muffler
  #3 (permalink)
Old 05-11-2008, 09:22 AM
Club Wagon is starting off with a positive reputation.
Where was the oil leaking?
Quote:
just oil EVERYWHERE
  #4 (permalink)
Old 05-11-2008, 09:57 AM
the best i can tell is the front seal and all around the oil pan. couldnt see very well from laying on the ground, but i saw no holes.maybe the mechanic can see better on the lift
thanx for the responses guys
mike
  #5 (permalink)
Old 05-11-2008, 02:55 PM
Well good luck. Hopefully its not serious.. but from what you described it doesnt sound good.
__________________
-No Muffler
  #6 (permalink)
Old 05-11-2008, 03:52 PM
galaxie641 is starting off with a positive reputation.
Sounds a lot like a hydrolock except for the tapping on the starter to get it going.
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #7 (permalink)
Old 05-11-2008, 06:15 PM
h20fella is starting off with a positive reputation.
funny thing, I went on vacation in feb, when I got back, my 4.6 would not start, I changed the starter, still nothing. I put a johnson bar with a pipe on the crank, and two guys could not turn the engine. the guy at the dealer said hydrolock is possible. I'm bummed too, cause I still owe 3000 on it.
  #8 (permalink)
Old 05-11-2008, 07:03 PM
now that you mention it, another guy at work said that is possible.he just went thru it with his chevy. thanx agin for your help,
mike
  #9 (permalink)
Old 05-11-2008, 07:37 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Welcome to the forum.
Sorry that this bad condition is what brought you here.
Hydrolock. A cylinder filled with coolant from either a leaking head gasket or intake gasket. When you cranked it over, it tried to compress the coolant and it can't be done, so the connecting rod gave way and exited the block.
Time for a new engine, your shortblock is toast.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #10 (permalink)
Old 05-12-2008, 02:44 PM
LxMan1,
thank you for your post as well as everyone else...this is what i suspected.i forgot that tha coolant kept getting low and never could figure out why. i never saw any leaks or smelled coolant. then, a guy at work told me today that last week before the motor blew, he was following me and it was blowing white exhaust for about a half mile then it stopped and cleared up. i guess it all adds up, put 2 and 2 together and you get a blown motor!
thanx for your help,
mike
  #11 (permalink)
Old 05-14-2008, 07:51 PM
hi guys,
quick question...a couple of different people have told me that in order to change the head gaskets or the motor on my 98 F150 4.2, i am going to have to remove the cab. is this true, or are these guys talking out their backsides?
mike
  #12 (permalink)
Old 05-14-2008, 08:15 PM
LxMan1's Avatar
No, the 4.2 should come out thru the top.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #13 (permalink)
Old 05-14-2008, 08:22 PM
thamk you LxMan1...i was beginning to think i was going to have a coronary to go along with the depression. now to come up with the cash to git r dun. any special things i should know or tricks...or will this motor slide right out like the old style! it looks as though it is shoved back in there a half a mile.
thanx again,
mike
  #14 (permalink)
Old 05-14-2008, 09:58 PM
LxMan1's Avatar
It's back in there, but small enough to come out. On the 5.4L is is easier to lift the cab off fo the frame, but can be done thru the top, just a really tight fit.
__________________
88 5.0 LX Mustang
63 F100 351W/C6
  #15 (permalink)
Old 05-15-2008, 03:14 PM
thanx again...greatly appreciate it.
mike
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
