on my '83 steering column, there looks like there should be tilt wheel because there's a joint and the wheel sort of tilts up from there sitting really high. where is the lever supposed to be?? anyone got pics??
if you do the turn signal lever needs to push foward to ajust tilt be careful sometimes on older trucks you may need to wiggle wheel some to get it to release good luck
__________________
1981 f-150 soon to be a 350 dually
I had my truck for a year before I discovered it had tilt steering. My wife actually found out before me. I saw her flip the wheel up to get out of the truck and I was like WTF did you just do!
__________________ 1985 F-250HD XLT Lariat Supercab 4X4 460/5spd with a body swap.
2000 Mustang 3.8/AT
1979 Capri 302/5spd
1967 Mustang 351W/4spd
Sounds of the stacks- http://s107.photobucket.com/albums/m...t=DSCF0270.flv
going out to the 86 tonite to see if it has a tilt wheel....
__________________
If you need any computer help/advice, pm me.
-94 f250 XLT 4x4, 7.5L, E4OD
-86 f250 XL 4x2, 6.9L, C6
-95 Nissan Hardbody, 2.4L, 5spd <-- The real work horse!
"Greater love has no one than this, that he lay down his life for his friends" - John 15:13
Yeah pre '92s with a turn signal stalk that can push forward got the tilt. Obviously this wont work for the mulitifunction switch on the '92+ so they have a separate control.
__________________
