Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 08:16 AM
DeadManWalkin's Avatar
DeadManWalkin is starting off with a positive reputation.
33 x 12.50 tires on 2wd F250
I'm trying to put 33 x 12.50 tires all the way around my 1990 F250 extended cab 7.3L Diesel w/5 speed manual transmission, 2wd.
The rear tires fit perfect but the front do not. I tried to find a coil spring spacer but I keep getting that one is not available for this year model.
I did purchase a set of 1 ton coil springs that will fit and raise the front end by a couple of inches, but it doesn't look to be enough.
My question is...........Has anyone here done this? and if so, can you give me some advice on what I need to do to get these tires and wheels on my truck without rubbing anything on the front end?
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 12:41 PM
tjc transport's Avatar
I AIN'T RITE!!!
tjc transport has much to be proud oftjc transport has much to be proud oftjc transport has much to be proud oftjc transport has much to be proud oftjc transport has much to be proud oftjc transport has much to be proud oftjc transport has much to be proud oftjc transport has much to be proud oftjc transport has much to be proud of
i put a set of 33X12.5X16.5 tires with american racing outlaw II rims on my nephews 88 F250 4X2 and they fit perfectly without doing anything.
__________________
Join me in the New Jersey Chapter, CLICK HERE!
NEW JERSEY CHAPTER LEADER
Tom
65 falcon 2dr h/t hot 289/C4
66 7 litre 4 speed convertible
79 F250 4X4 plow rig 351M C6
88 superduty diesel 4X4 C6 and banks turbo
99 crown vic P71 interceptor
02 F250 superduty diesel 4X4 stretchcab shortbox
  #3 (permalink)
Old 05-11-2008, 12:45 PM
Elias is starting off with a positive reputation.
its a cake walk chief
its easy bro, put 1in spacers on it and you might have to grind out the back of the fender, its easy though did it on my moms truck with stock suspension with no body lift
  #4 (permalink)
Old 05-11-2008, 12:46 PM
1in wheel spacers not coil spacers thought id clear that up, i confuse myself sometimes lol
  #5 (permalink)
Old 05-12-2008, 07:53 AM
thomas k is starting off with a positive reputation.
33's
i used a2 inch lift on my 90 150 without wheel spacers has slight rubbing on frame without damage to tires and only rubs when turned to the max been this way for 3 years now
  #6 (permalink)
Old 05-12-2008, 10:33 AM
Thanks for your replies, I'll put these 1 ton coils under the front and see if it's enough then we'll go from there.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
