Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 05-11-2008, 07:34 AM
jay54f100's Avatar
jay54f100 jay54f100 is offline
Garage is empty, add now
jay54f100 is starting off with a positive reputation.
Looking for a good machine shop Denver, CO. area?
I have an 85' 250 460 4sd 4x4 and need the engin rebuilt. I will do the pulling if they will do the machining. Anybody have a good one to go to and get a quote. I saw a thread on this all ready but it is 5 years old. It can be outside of Denver to. Thanks for the help. This site
  #2 (permalink)
Old 05-11-2008, 10:16 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
ctubutis ctubutis ctubutis
I'd be interested in similar recommendations in the Denver metro area, I have an
81 400 I'm considering having some things done to (hopefully just cam bearings
but we'll see).
-ct
  #3 (permalink)
Old 05-12-2008, 09:38 PM
Colo79Ford Colo79Ford is offline
Colo79Ford is starting off with a positive reputation.
I VERY HIGHLY recommend Romeys automotive machining, 303-629-0561. They are at 859 north federal, in denver. These are the guys who built the 400 in my truck and that engine has taken way more abuse than i ever imagined it could, and still does not miss a lick. They have also done quite a few engines for my friends (racing buddies) anything from OEM rebuilds to very high performance engines. Just let them know that John from Georgetown sent you down there and they will take good care of you, just like they do with all of their good customers.
__________________
My truck
  #4 (permalink)
Old 05-12-2008, 09:40 PM
Hey, ct, if you have the engine that far apart (cam bearings) you might aswell have everything machined and the heads freshened up.
__________________
My truck
  #5 (permalink)
Old 05-13-2008, 07:44 PM
ctubutis's Avatar
Quote:
This is what I'm debating about but haven't decided on (nothing is taken apart yet, I'm intending it to be a summer project). I wanna post/ask some stuff on the 335 forum but maybe I'll begin here.
1981 F350 400 4x4 T18 4.10 31" tires Holley 4412 2V headers true duals. No idea of true mileage, odo reads 94k but the title says 0 so I have no idea if the odo has rolled over perhaps N number of times + the PO had it only for a year or so (bought it from his boss, it spent its life as a Farm Truck in Ft. Lupton) and didn't know much about it. All the emissions controls have been removed/disabled, it passes the sniff test using VERY fine tweaking of the carb + creating an intentional vacuum leak. (This is a different story, maybe I'll explain more later.)
This thing has allegedly been rebuilt once supposedly by a reputable shop in Denver but that was two owners + an unknown number of miles ago. Oil (20W50) pressure is approx 35 at hot idle, approx 60-65 when moving. Vacuum is 16 in & steady. All cylinders have 140-150 psi compression EXCEPT FOR #1 which has 130 BUT it goes up the same 10-15 lbs. after adding oil that the others do.
This project began as installing a 4V carb - 670CFM Holley Truck Avenger, Eddy Performer 400 EGR manifold; these are parts that I acquired over the past year. Last Fall it began blowing blue smoke for a few minutes on startup, I don't like that. When I replaced the clutch & installed headers last Fall I found a LOT more black gunk in the #4 exhaust port than any others + the #4 plug had a lot of black buildup on it. I'm not sure if it's oil or gas or what, it could very well be from an ignition problem to that cylinder.
So, taking the heads off and having them redone (assuming valve guide seal problem here, perhaps the guides themselves) isn't *that much* more work once the intake manifold is off.
When the crankcase filled with gasoline last Winter (http://www.ford-trucks.com/forums/70...ml#post5749513) I took the opportunity to stick my finger in the hole in the timing chain cover and found that I need a timing chain pretty badly, it felt like there was at least 3/4 of an inch of slop there (which makes me wonder how many miles have been put on the thing since it was last rebuilt).
So, now the top AND the front have to come off. After last Winter's episode, it's kinda lookin' like an oil pan gasket is now in order, too. Which is a great time to replace the rear main seal. At which point it's probably easiest to just take the engine out and take it apart all over the garage floor. Which is a great time to replace the input & output shaft seals on the tranny, I guess.
I put less than 1,000 miles per year on the thing and use it mostly for hauling trailers full of firewood in the winter; mostly along the front range area but I sometimes cut & haul back to Denver the black stuff from the Hayman burn area up near Conifer.
What I'm really hoping for is to not have to do anything to the bottom end, mostly because I'm afraid of the expense + it's probably already been bored once and .060 over is too much for this engine IMHO. Since it needs a timing chain, this might be a great time to install one at 0deg offset (instead of 4deg retarded) and, ideally, a new cam. Since I'm doing the heads, the lifters & springs & whatnot would be part of it. I'm kinda looking forward to doing it myself so I can learn something about it; my father used to build stock car engines in the 60s & 70s and he knows a fair amount of this stuff and will help but I've never done it (although I just recently got a copy of the Tom Monroe book + my brother is pretty good at this stuff).
The first questions are:
  • Will it pass emissions with a 0deg offset chain + maybe a 255DEH?
  • My engine may already have something non-stock seeing as how it was already rebuilt once, there's probably no way to see what cam I have than to take it out and measure it, correct? My understanding is that I shouldn't replace a cam without also replacing its bearings.
If I remove & disassemble the engine I can at least see what it is I've got by taking various measurements here & there, I guess. But I don't want to perform work/spend money that isn't needed. I'm not interested in a Bandimere top-10 contender, it's an ugly, rusty, work truck (crappy cellphone pix in my gallery) that I want to haul a few thousand pounds of firewood + get me out & around when we have waist-high snow (which is actually quite fun . Bodywork I guess will have to come next year; I have a front clip + doors from an 82 F250, need floor pans + rocker panels + a bed.
So, whatya think? I don't dare try and post all that at once to the 335 forum, it's too long and nobody would read it (much less answer).
-chris
P.S. Thanks for the recommendations for the shop on Federal!!!
  #6 (permalink)
Old 10-12-2008, 09:50 AM
DarkWolf40's Avatar
DarkWolf40 DarkWolf40 is offline
DarkWolf40 is starting off with a positive reputation.
Drive Train Industries - near Washinton and I70
  #7 (permalink)
Old 02-21-2009, 02:21 AM
rkymtnman30 rkymtnman30 is offline
rkymtnman30 is starting off with a positive reputation.
I was suprised no one mentioned Blue Oval in Englewood great with Fords. Split Fire off of 64th and Federal is good with performance machining.
__________________
RkyMtnMan
Running wild through the 14'ers
1986 F-150 4 X 4 5.0L one hell of a mountain goat
1991 F-250 4 X 4 5.8L the elk buggy
  #8 (permalink)
Old 02-21-2009, 11:26 AM
Hypoid's Avatar
Hypoid Hypoid is offline
Hypoid is gaining momentum as a positive member of FTE.Hypoid is gaining momentum as a positive member of FTE.
X2!
MPG head service is another shop that has been recomended to me, although pricey.
I've heard some not so impressive things about Romey's since the kids took it over.
Rob McQ will be getting the FE work I need to farm out. I have yet to hear a harsh comment about the guy or his work.
__________________
NO PRIDE-NO SHAME
'74 F-100 4x4: It's ugly, loud and smelly. Those are it's good points!
'96 Ranger XLT, 2.3L, 5-speed, 2 wheel drive.
Email me at Hypoids.haus at yahoo, visit me at RMFTC.com/forums
  #9 (permalink)
Old 03-25-2009, 10:01 AM
Mike G Mike G is offline
Mike G is starting off with a positive reputation.
Quote:
Originally Posted by Hypoid View Post
X2!
MPG is one street over from Blue Oval in Englewood... Rob did the machine work to my FE but can build anything Ford, believe me. If I could have afforded to have him do a full build, that would have been very nice. He is very picky about his work, so if you take a different route, be firm. He is also very talk-ative and loaded with info and ideas, just tap in and start taking notes.
--Mike
__________________
Mike G
The Ford related items representing 1/3 of what's in the garage....
1965 F100 LWB 401FE power and C6
1968 Cougar XR7 (wife's toy)
2001 F350 Long-Crew-Dual-4x4-7.3L TD Hoss
  #10 (permalink)
Old 03-25-2009, 12:41 PM
mwvdub's Avatar
mwvdub mwvdub is offline
1979 Ford F-100
mwvdub has a good reputation on FTE.mwvdub has a good reputation on FTE.mwvdub has a good reputation on FTE.
I have had some pretty serious issues with using MPG. I am talking blown engines that run for 2 minutes and heads that are not water tight.
__________________
Miles
1979 F100-11.47@117 @ 5800'
2004 Ford F250 KR
2010 Polaris Ranger RZR-S
Click Here to Join the Wyoming Chapter
  #11 (permalink)
Old 04-12-2009, 12:53 PM
DarkWolf40's Avatar
Yea, Blue Oval built my 410, it kicks a$$. Rob's a good guy but I had a little trouble with him getting all the bugs worked out.
  #12 (permalink)
Old 06-05-2012, 10:36 PM
Half bus half truck Half bus half truck is offline
Half bus half truck is starting off with a positive reputation.
Thumbs up
Quote:
Rob and Blue Oval Performance Engineering is building a 410 for me as well. I'm impressed with his knowledge and experience. I've been around for a long time and not easily impressed. Rob is the best Ford guy, I've met.
3761 South Kalamath Street, Englewood, CO
(303) 762-8298
@DarkWolf, I'd really like to know more about yours. (I haven't got mine back yet.)
  #13 (permalink)
Old 06-08-2012, 01:25 AM
CS79bronco CS79bronco is offline
CS79bronco is gaining momentum as a positive member of FTE.
Wow, this thread is 3 years old.
__________________
95 Bronco-5.0 going to 7.5/ZF5 & 33's
86 Bronco-5.0-NP435-35's-stock suspension
79 Bronco-410ci-NP435-203/205-35's (in the works)
90 F350 7.3-C6-box truck (for sale)
77 E350-460-C6-18' RV
  #14 (permalink)
Old 06-10-2012, 11:22 AM
Shawns Fords's Avatar
Shawns Fords Shawns Fords is offline
Shawns Fords is starting off with a positive reputation.
I know a lot of big power Racers that go with MPG Heads and I know Scott does top notch work there. He still has my 429 down there waiting for my big paycheck to come in.
Rob at Blue Oval has also done some great work for a lot of folks as well.
I just had the guys at AMS automotive machine Balance my flywheel for my F250 and it was affordable and reasonable, they also build a lot of the Drag racers engines.
AMS Automotive Machine - Engine Builder, Engine Rebuilder, Race Engines
  #15 (permalink)
Old 06-12-2012, 06:12 PM
AzPatMan's Avatar
AzPatMan AzPatMan is offline
2003 Ford Excursion
AzPatMan is a name known to allAzPatMan is a name known to allAzPatMan is a name known to allAzPatMan is a name known to allAzPatMan is a name known to allAzPatMan is a name known to all
I've used Blue Oval and MPG as well.
Also - G&S in Littleton - on Platte Canyon.
Also - quick/minor thread jack.
Shawn? From CDR?
__________________
h<font color=#000000>ttps://lh4.googleusercontent.com/-lxbT22oj5Dk/T6GIqbi11AI/AAAAAAAAAHk/Qva7BrSHDEE/s912/Ex-Towing.jpg</font>
2003 Excursion 7.3L,4inch Lift, My DIY LED DRL mod. 325/65/18 Hankook Dynapro ATM on KMC XD Spy's,4inch Diamond Eye Exhaust, AFE Stage1 CAI.
Coming Soon: 6.0 IC, new boots, gauges, New plenum and intake, home-built Turbo, TW Tunes on a Ts-Chip.
Tags
area, co, colorado, davidson, denver, federal, flathead, ford, good, gooddsm, harley, machine, reputable, shop, shops, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
