Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 07:26 AM
playsinmud is starting off with a positive reputation.
Need Help '87 460
Hi. I will explain what I have and then my problem..
I have a 460 out of a 87 F250 in a 89 chevy blazer I use just for off roading.
I've taken the old carb off and put a Holley 770 Dominator on it. MSD 6A with a blaster coil. No exhaust just open headers. The egr plate on the original mainfold is left in place. The jets for the 770 are stock. This is the carb recomended by Holleys site. checked for vaccume leakes and can't find any.
I can't get the truck to idle at any rpm less than 1300-1500. Then if you put it in gear it just dies... I was told the setup for this engine is 8* of timing however I'm not sure about that.
I'm pritty much a chevy guy trying to learn the ropes of the big bad ford... I've got it at about 20* of timeing now if I go to 8* it just backfires thru the carb.
Please help I want to make this a trailable rig but cant with the crazy idle speed.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 10:11 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
OK.. first thing you need to do is go get a big "Powered By Ford" decal for the back window, the motor will immediately start to run better.
What firing order do you have the plugs wired for? It should be 15426378, the distributor turns counter clockwise, and cylinder #1 is passenger side front.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
  #3 (permalink)
Old 05-11-2008, 04:03 PM
Ok I don't want to sound stupid but give me the run down for the rest of the cylinders and I'll check it. Does the rotor face #1 like on a chevy?
  #4 (permalink)
Old 05-13-2008, 05:54 AM
Firing order is right! Any other suggestions?
  #5 (permalink)
Old 05-13-2008, 11:37 AM
Franken-Truck's Avatar
Chick'n tastes like Human
Franken-Truck has a good reputation on FTE.Franken-Truck has a good reputation on FTE.
when you check the timing, did you pull the vacuum line off the vacuum advance? Have you checked your idle adjustments? Have you sprayed water/wd-40/rubbing alcohol/ether around the base of the carb and around your intake to check for leaks?
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4
VIRGINIA CHAPTER
Virginia Chapter Website
  #6 (permalink)
Old 05-14-2008, 01:09 PM
Conanski's Avatar
Quote:
OK, the cylinders are numbered front to back 1-4 on passenger side and 5-8 on the driver's side. With the #1 piston on TDC of the compression stroke the distributor button should point to post #1, it's easy to get this 180 degrees off if you don't make sure the motor is on the compression stroke.
__________________
Paul O
  #7 (permalink)
Old 05-14-2008, 05:35 PM
Yes vaccum was disconnected and yes I checked for leaks. Do you think is lack of back pressure?
  #8 (permalink)
Old 05-14-2008, 08:27 PM
vernon1512 is starting off with a positive reputation.
check both ends of the big vacuum hoses, I have knocked off the brake booster hose at the booster changing a carb. It took most of a 12 pack to find it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
