Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 06:28 AM
Redneck86ford is starting off with a positive reputation.
86 302 efi HELP!!!!!!
I just bought a 86 f150 runs and drives great but it has a hole in the rear tank and the previous owner said when ever he drove it it would just die while going down and he would let it sit for a half gour and it would start right he called it vapor lock but i thought that was when the fuel gets to hot but not sure and it did it to me the other day it just dies no spudder or anything does this sound right? And will it fix it with a patch it cuz i have heard of people just not using that tank and they drive every day?
  #2 (permalink)
Old 05-11-2008, 07:49 AM
ctubutis is starting off with a positive reputation.
Just dying without any sputtering sounds to me more like ignition than gas, and I've
heard stories of ignition modules failing when they get hot. Next time this happens,
check for both gas and spark (though I don't know how to check for gas on an
engine with EFI but somebody here will help you). In any case, I don't think a hole in
a gas tank will cause your problems.
-ct
  #3 (permalink)
Old 05-11-2008, 08:01 AM
81-F-150-Explorer is gaining momentum as a positive member of FTE.81-F-150-Explorer is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by ctubutis View Post
I've heard stories of ignition modules failing when they get hot.
I would say that this was the problem.
And I recomend getting the gas tank fixed or swapped with a new one asap.
  #4 (permalink)
Old 05-12-2008, 12:14 AM
brthevio's Avatar
brthevio is starting off with a positive reputation.
I have both
I have good news for you, I have both an ignition module and a good rear tank. Both from an 86 F150 with a 302. I would have to find the Ignition module but I know I have one. If you are interested let me know. I am pretty sure that both the sending unit and fuel pump in the rear tank still worked also. Make me an offer. You would have to pay the shipping though.
__________________
81 F-150 Ranger
351M
C6
9" rear
86 Interior
THE HEARTBEAT STOPS HERE!!!!!
  #5 (permalink)
Old 05-12-2008, 06:47 AM
mjsizzle is starting off with a positive reputation.
put a can of starter fluid in the truck, next time it quits give it a little sniff, (just a short shot!!) if it starts and quits its fuel, if not its ignition or, carry a spark tester, when it quits put it inline on a spark plug and make sure its in neutral, switch on, short the solenoid with a old screwdriver, if it shows fire then its fuel if not get the module and put it on
and like 81-f-150-explorer said, get that tank repaired, it will cause many problems
  #6 (permalink)
Old 05-12-2008, 10:23 PM
brthevio's Avatar
Checking fuel
On the fuel rail, can't remember which one, there should be what looks like a valve stem for a tire. If you are by yourself, turn the truck over a few times, then take the cap off of the valve stem looking port. Push in on the stem inside and if the motor is getting fuel it should have pressure on it. Watch your eyes. If there is pressure it will sometimes spray pretty hard. I put a rag over it then push it in to stop the fuel from getting everywhere. If you have someone else there they can turn the key on while you hold the stem in. When the key is turned on the pump kicks in for a second and you should get pressure at the fuel rail. I can't remember all that you said you checked but on the 86 parts truck that I have I know it actually has 2 fuel filters on it. I have dual tanks. The second, and less known filter is on the inside of the frame rail below the drivers door. You have to unscrew the casing and it has one of the open element filters inside. You could check and see if it is plugged. Anyway I hope this helps. I am listing the 86 parts truck that I have on the classifieds section on here. Check it out. I know I have some parts that you could use.
__________________
81 F-150 Ranger
351M
C6
9" rear
86 Interior
  #7 (permalink)
Old 06-01-2008, 07:46 AM
Smile
I got a new ignition module and still dies, with no spark so its not fuel, could it be the coil going bad or??? im terrible with ingnition stuff ANY HELP WOULD BE GREAT WANT TO START BUILDING TRUCK FOR MUD DRAGS!!!! THANKS
  #8 (permalink)
Old 06-01-2008, 09:13 AM
Franklin2's Avatar
Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.Franklin2 has a great reputation on FTE.
I think I will put this in my signature. When troubleshooting a EFI engine, always pull the codes first
__________________
Dave F
1989 F250 XLT Diesel
  #9 (permalink)
Old 06-02-2008, 12:12 PM
blue beast's Avatar
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
A multimeter will help figure if the coils values are okay. So get one if you don't have one
IF it seems to be a heat related thing a can of keyboard duster or two kept in the
truck and go for a ride and when it dies, start by spraying the tfi module(side of dist)
for a good 7-10 seconds while holding the can upside down so the freon comes out and
then try strating the truck, no go? then pull off the cap and spray inside the distributor
for 5 or so seconds (let the freon residue evaporate) reinstall cap and try to start.
Basically you want to just go down the line and try to cool the components and when
it starts you can try to recreate the problem again or more then likely it was the last
component you chilled. Heat related failure or even just the resistance level changing
from heat is a problem. Cryodiagnostics!! Of course there is a high dollar can of stuff
you can buy that is made for diagnosing heat related failures in transmitters and
other stuff but for 2.99 you can do the same thing. Of course don't spray your fingers
wear eye protection and the time and amount of spray needs to be adjusted for some
materials since metal conducts better etc.
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
04 Ranger edge 3.0 5 speed auto 4.10
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!!!!!!
There now I don't have to say it every time!!!!
  #10 (permalink)
Old 06-03-2008, 05:05 PM
gonzales7727's Avatar
gonzales7727 is starting off with a positive reputation.
ok, i have the same truck year model everything as this guy, and i have the same problem, but i think i know what it might be.
someone once told me that theres a valve switch between the 2 tanks and the switch on the valve is bad, or maybe it's just the fuel pump going bad.
__________________
" Took off the resticter plates off to give the Red Dragon a little more juice "
  #11 (permalink)
Old 06-03-2008, 05:30 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
I had the same symthoms with my '86
there is a harness that comes from the bottom on the left bank that had rubbed and shorted
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #12 (permalink)
Old 06-07-2008, 05:48 PM
i guess i should have tried the starting fluid thing first cuz it will fire with it i just assumed it was ignition by the way it was shuting off, so i was wondering if i just cancel out the rear tank all together by just plugging both of the hoses that running to the front? or how would i o about doing it? thanks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
