That is very outdated. It was probably accurate back in the 60's, but modern automatics have much better materials and are not harmed by high temperatures like that chart shows.
__________________ Mark
Former Ford automatic transmission engineer, 1988-2007.
Interesting, thanks Mark. So other questions then, given your background: I have a 93 F-150 5.0L 4wd LB with a recently rebuilt AOD. 2-3 days a week I haul 100-200 miles, enclosed trailer and load avg 2500-3000 lbs. Sometime 5000lbs for short trips under 20 miles. Foothills and some 2-3 mile grades up to 5-6%.
I have an external trans cooler but want to add a temp gauge. Where do you rest on the sender placement debate, and is an add-on external filter too redundant?
Does my AOD qualify as a "modern transmission"? (It was rebuilt by a local shop, "the old guy" has been around forever, and used "upgrades" on all internal parts).
What temp ranges should I be concerned with?
Many thanks in advance,
Erik
__________________
Braccae tuae aperiuntur
'93 F-150 4x4 Supercab Longbed, 5.0L, AOD, BFD...No Mods.
'94 Lincoln Town Car
'93 Taurus Wagon, 3.8L . Dog is my co-pilot.
Yes materials have changed over the years but the majority of that change is in the aftermarket.
Manufacturers for the most part still use materials that don't handle heat well.
Fluid is still succeptible to high heat as are gaskets.
Seals harden and start to leak internally.
Once that happens slippage begins.
The temperature chart is still accurate for longivity.
Ultimate temperature is 170*.
The connection that will read the hottest is in a cooler line leading to the cooler.
__________________
Transmission builder since 1964.
2002 Ranger.
3.0 engine.
Thanks guys. I was leaning towards the pressure side, so I guess that'll be it. I may get fancy just for the heck of it and put in two sensors with one gauge, one on each side of the coolers with a switch to toggle back and forth.
__________________
