Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 12:45 AM
e1p1's Avatar
e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.e1p1 has a good reputation on FTE.
Does this temp chart look right?
Actually got this off an old thread, I bookmarked it. Does this look right ot you guys?
Performance Unlimited 4-Wheel & Off Road Center - Hartford, Wisconsin - USA Technical Documents
__________________
Braccae tuae aperiuntur
'93 F-150 4x4 Supercab Longbed, 5.0L, AOD, BFD...No Mods.
'94 Lincoln Town Car
'93 Taurus Wagon, 3.8L . Dog is my co-pilot.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 08:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.Mark Kovalsky has a very good reputation on FTE.
I can only speak to the trans portion.
That is very outdated. It was probably accurate back in the 60's, but modern automatics have much better materials and are not harmed by high temperatures like that chart shows.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #3 (permalink)
Old 05-11-2008, 10:24 AM
e1p1's Avatar
Interesting, thanks Mark. So other questions then, given your background: I have a 93 F-150 5.0L 4wd LB with a recently rebuilt AOD. 2-3 days a week I haul 100-200 miles, enclosed trailer and load avg 2500-3000 lbs. Sometime 5000lbs for short trips under 20 miles. Foothills and some 2-3 mile grades up to 5-6%.
I have an external trans cooler but want to add a temp gauge. Where do you rest on the sender placement debate, and is an add-on external filter too redundant?
Does my AOD qualify as a "modern transmission"? (It was rebuilt by a local shop, "the old guy" has been around forever, and used "upgrades" on all internal parts).
What temp ranges should I be concerned with?
Many thanks in advance,
Erik
__________________
  #4 (permalink)
Old 05-11-2008, 11:24 AM
I like the temp sensor in the pressure port in the driver's side of the trans.
The AOD is a modern trans with modern, high temp materials. The max sustained temp is 220F, the short term (less than a half hour) is 250F.
__________________
Mark
  #5 (permalink)
Old 05-11-2008, 11:31 AM
stuart1 is gaining momentum as a positive member of FTE.
I agree with Mark up to a point.
Yes materials have changed over the years but the majority of that change is in the aftermarket.
Manufacturers for the most part still use materials that don't handle heat well.
Fluid is still succeptible to high heat as are gaskets.
Seals harden and start to leak internally.
Once that happens slippage begins.
The temperature chart is still accurate for longivity.
Ultimate temperature is 170*.
The connection that will read the hottest is in a cooler line leading to the cooler.
__________________
Transmission builder since 1964.
2002 Ranger.
3.0 engine.
  #6 (permalink)
Old 05-14-2008, 12:49 AM
e1p1's Avatar
Thanks guys. I was leaning towards the pressure side, so I guess that'll be it. I may get fancy just for the heck of it and put in two sensors with one gauge, one on each side of the coolers with a switch to toggle back and forth.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
