Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-11-2008, 12:06 AM
stangdano is starting off with a positive reputation.
Question Easy way to drain oil in 9 inch rear diff?
Does anyone know of an easy way to drain the rear diff on a 9 inch rear? It doesn't have a drain plug and I'm not much in the mood to pull the axles and split the housing apart. Any help is appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-11-2008, 03:02 AM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
THere is a tool available called a suction gun. Looks like a grease gun without the pump handle. You can stick the hose into the fill hole and suck out the old oil. You will not get all of it by doing it this way, but it will be close enough to make the new oil new.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 05-11-2008, 03:11 AM
Bush_aholic is starting off with a positive reputation.
I would pull the rear housing either way, I would much rather know I was able to take a glance at the gears and inspect for any unusual wear and have a fresh RTV seal. IMO
I might be missing something here, but you said pull the axles apart, can't you just pull the rear diff cover nothing else?
  #4 (permalink)
Old 05-11-2008, 09:50 AM
1975StroppeBaja's Avatar
1975StroppeBaja is starting off with a positive reputation.
Quote:
Not on a 9" rear. Its a third member where the ring, pinion, carrier, etc all comes out of the housing as an assembly. Its not like a Dana 60 or Dana 44 or most other differentials.
__________________
2004 F250 XLT Sport CC, 5.4L, 4.10LS
  #5 (permalink)
Old 05-11-2008, 10:10 AM
That's good to know, I can see why he wouldn't want to take it apart just for an oil change.
  #6 (permalink)
Old 05-11-2008, 06:33 PM
Thanks for all of the feedback, everyone!
I tried using a suction gun but didn't have any luck. There's really no clearance between the ring gear and the side of the housing to get the tube down to the bottom of the diff. I also tried using the old siphon method, but that seemed like it would take way too long, not to mention it didn't taste so good.
So I came up with an interesting way to get most of the oil out easily. I have the truck up on jack stands and I noticed that if I spin the driveshaft, a little oil was coming out. So I started it up and put it in reverse and let the truck idle the oil out. Probably not the best way, but without being able to get the suction gun in there and not feeling like getting another mouthful of oil, it seemed like a decent idea.
The only possible bad side is that I'm not sure that I got all of the oil out, but I'll try to siphon it again and see if any more comes out.
Again, thanks for the feedback.
  #7 (permalink)
Old 05-13-2008, 09:42 PM
dodmort is starting off with a positive reputation.
Well
i was told how foolish i was for doing this but..
i drilled a very small hole in the back bottom curve of the housing and put in a very small screw with a washer and put a little sealant on it.
in 1986
so far i have had not a problem one...
reason is that it gets submerged in water 55-60 times a year and i like to change fluid....a lot..
__________________
24 t (not a sreet rod)
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
68 m715-fe,powered - 4 link
Rather have a bottle in front of me than a frontal lobotomy
  #8 (permalink)
Old 06-11-2008, 01:51 AM
Fordteamone is starting off with a positive reputation.
I have had good luck on two different 9" with drilling and tapping a 1/8" pipe plug.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
