Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 05-16-2008, 08:37 PM
cookie88's Avatar
cookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to behold
Probably not a bolt in deal on a 79, but I'll give the hydroboost in the big truck a good look over. Vacuum reservoir shouldn't be a big deal.
Andy. The way it's sitting right now this will be my fall/winter project, but I'll definitely holler at ya when I get into it.
Thanks for checking it out for me George.
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck
96 Merc Grand Marquis (hers) mostly stock 4.6
68 Merc Montego completely stock s-code (275HP 2bbl) 390
  #32 (permalink)
Old 05-17-2008, 08:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Measure the bolt pattern center to center where the brake booster mounts to the firewall.
I am going to bet it is the same, just because it was not changed from an 86 F 250 to a 97 Super Duty (F 450).
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #33 (permalink)
Old 05-18-2008, 10:48 AM
stevilknevil's Avatar
stevilknevil is starting off with a positive reputation.
if the hydra-boost works that will make a lot more room to work with
__________________
'79 f-250 7.3 idi,4x4,4.56 gears,4-speed,some rust,lots of fun
  #34 (permalink)
Old 05-18-2008, 01:35 PM
AndysFords is starting off with a positive reputation.
I opened the hood on an 89 F350 at a junk yard a year or so ago and it had a hydraboost, so it can be done.
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6 w/ GearVendors Overdrive currently in a deep sleep until motor overhaul is finished. 1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual. (3) 1976 F250 Reg Cab 4x4 All 390, two C6 and one 4 spd.
  #35 (permalink)
Old 05-18-2008, 02:57 PM
I am running hydraboost on my 86 F250, direct bolt on install.
I am using the hydraboost unit off a 97 F450 with my 86 master cylinder and a 97 power steering pump with the 86 pulley on it.
Real brakes.
__________________
"I dig dirt"
WV Chapter Member
  #36 (permalink)
Old 05-21-2008, 08:16 PM
cookie88's Avatar
Thanks guys....I'll look into it.
Sorry 'bout the delay replying. Had to go out of town this weekend to rescure the wife's Grand Marquis.....then had to replace the cracked intake manifold.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
