Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-11-2008, 12:29 AM
cookie88's Avatar
cookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to beholdcookie88 is a splendid one to behold
If I keep a 1:1 tranny, what's the useable RPM range? Is it going to tear it up screaming down the interstate at 3K rpm every day?
__________________
Scott - FTE moderator
01 F-250 Lariat, 7.3, ZF-6, NV271, -38R, SII splits, DI tunes, Custom fuel, IDM140....and more little mods than I can remember.
79 Bronco- 7.3 IDI diesel project truck - AWM
96 Merc Grand Marquis (hers) mostly stock 4.6
68 Merc Montego completely stock s-code (275HP 2bbl) 390 - AWM
  #17 (permalink)
Old 05-11-2008, 12:35 AM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.Dave Sponaugle has a great reputation on FTE.
Fuel mileage will suffer, big time at that RPM.
Your wallet will suffer much more than the engine will, even at 3300 RPM all day.
1000 to 3300 RPM.....in something as small as a Bronco, the 750 to 3300 RPM range will all be useable.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
www.ford-trucks.com/guidelines.html
FTE Moderator in the IDI diesel forum.
WV Chapter Member
  #18 (permalink)
catfish101's Avatar
catfish101 is starting off with a positive reputation.
You have 4.10s still or have you changed them. I believe I would swap to a 3.55 gear at least. They should be easy to find. The Ford 9", that you have, shouldn't be to hard to find in 3.55.
Well 10 years ago it wouldn't have been but times have changed and scrap metal has been up.
__________________
79/83/86/95 F-??? 6.9 4speed
94 350 4x4 SRW 7.3 factory turbo
1930 Model A Original
My wife has three of her own.
  #19 (permalink)
Old 05-11-2008, 12:41 AM
cookie88's Avatar
I've got the stock 3.50LS gears. It's a bit of turd now with the 35" tires, but I see them being a good thing with the diesel torque. Prolly help those highway revs too.
What about an AOD...no compter needed. Was there ever one behind an IDI. If there was, how to mount the kickdown lever?
__________________
  #20 (permalink)
Old 05-11-2008, 08:46 AM
catfish101's Avatar
3.50s?? I haven't ever seen a option other then 410s in a 78 or 79 Bronco.
I'll be dam###.
__________________
  #21 (permalink)
Old 05-11-2008, 11:54 AM
No AOD behind the diesel, E4OD was the only overdrive automatic.
__________________
"I dig dirt"
WV Chapter Member
  #22 (permalink)
Old 05-11-2008, 12:08 PM
stevilknevil's Avatar
stevilknevil is starting off with a positive reputation.
Quote:
Originally Posted by cookie88 View Post
Thanks Dave....that almost makes that part a no brainer.
Steve. When you built the motor mounts, did you move them back any for better weight distribution, or line them up with the factory mounts?
no on my truck i had to move everything forward to clear the firewall
__________________
'79 f-250 7.3 idi,4x4,4.56 gears,4-speed,some rust,lots of fun
  #23 (permalink)
Old 05-11-2008, 01:01 PM
George D.'s Avatar
George D. is starting off with a positive reputation.
TCS Detailed Product Description - Baumann Electronic Controls, LLC Heres a link to the controller David 85 has. Its a pretty cool unit. You can custom tune almost every aspect of it. And they are about the same price a stock TCU. They also offer a shift kit that combined with this lets you make the trans shift exactly how you want.
As for hou they are controlled. You will need a FLPS fule lever position sensor hooks on the side of the IP basicly its a TPS, Then a tach signal and a speed signal wich both have to be very acurate. and of coures the wiring from the trans.
You will definately want to make some internal mods to the trans befor you put it in. If you have the funds I would rebuild the whole thing.
__________________
94 F350 Crew Cab Long bed 4X4 7.3L IDI Factory Turbo, AKA The Land Yacht. E4OD, 4.10 posi. Getting further from stock with 35 inch BFG alterains on 16 inch micky's, straight pipe, Triple A-piller pod with pyro, boost, modifyed stock oil presure gauge, tc lock light&switch
  #24 (permalink)
Old 05-11-2008, 02:13 PM
cookie88's Avatar
Quote:
Stock fan, or electrics? Which radiator did you use? I notice your blower box is missing. Did you have to remove it to fit the 7.3, or was it already gone?
Thanks for the input George, the E-tranny will probably have to wait. C6 rebuild kits are cheap.
__________________
  #25 (permalink)
Old 05-11-2008, 05:50 PM
my truck was a non a/c truck so it did'nt have one.i used the stock fan,the radiator is a 4 row from a 90's truck that a buddy gave me.i had to clearance the core support to get it in.it is not as wide as the one from the donor truck but it is a crossflow so it may be good enough?has been so far.i also set the motor above the front crossmember so i could keep the 7.3 power steering pump braket.
__________________
  #26 (permalink)
Old 05-15-2008, 10:04 PM
cookie88's Avatar
Does the IDI have a belt driven vacuum pump? Does it run the brake booster directly or is there a reservoir?
Or is it a hydroboost brake system?
__________________
  #27 (permalink)
Old 05-15-2008, 10:13 PM
George D.'s Avatar
Belt driven vacume pump. I want to say it runs straight to the booster but I think its gotta have a resivor now you got me woundering I'll have to go look. Also you could run hydroboost off of one if you wanted to.
__________________
  #28 (permalink)
Old 05-15-2008, 10:22 PM
George D.'s Avatar
Aperantly theres no resivor the line runs from the pump to a 2"x1"x5" vacume manifold and then to the booster.
__________________
  #29 (permalink)
Old 05-15-2008, 10:46 PM
AndysFords is starting off with a positive reputation.
My 84 had a resovoir with a small vacuum line going to it, but I took it off and plugged the line to make room for my heated fuel filter, still stops fine. Cookie, when you get finished or close can I come look, I'm thinking of doing the same thing with my 76, it blew the motor this summer, and I bought an old 86 Diesel at the auction running but the truck was rough as could be for $400, by the way if you want a 4 spd manual I got one right here in Lonoke.
__________________
1997 F250 Crew Cab 4x4
1988 F350 7.3 Crew Cab 4x4 Dually C6 w/ GearVendors Overdrive currently in a deep sleep until motor overhaul is finished. 1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual. (3) 1976 F250 Reg Cab 4x4 All 390, two C6 and one 4 spd.
  #30 (permalink)
Old 05-16-2008, 07:17 PM
A resovoir will give you more braking power or a vacuum reserve so you can make more brake applications while at low RPM's.
I am running a hydraboost system off a 97 Super Duty, bolt on fit, on my 86.
Now I have real brakes.
The hydraboost actually takes up less room, but more hoses than the vacuum booster does.
__________________
"I dig dirt"
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
