Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Exhaust Systems
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-10-2008, 07:02 PM
dfishrmn88's Avatar
dfishrmn88 is starting off with a positive reputation.
Catalytic Converter Failure
What would cause both Cat converters to fail at 20,000 mi.? Mine went out and the back pressure caused the engine to knock under acceleration. Also blew out an injector and plug. Luckily it was under warranty but wonder what could caused it. Thanks.
__________________
2005 F150 XLT SuperCab 5.4L V8 4x4, 3.73 LS Rear end, Auto Spring 2" Leveling Kit, Gryphon tuner, AEM Panel Air filter
  #2 (permalink)
Old 05-10-2008, 09:27 PM
kens64 is starting off with a positive reputation.
Running rich is the most common reason, as far as I know. Bad injectors and bad O2 sensors can cause the engine to run rich.
If whatever caused the first ones to go bad isnt fixed, your new ones will probably go bad too.
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
JOIN THE NEW MEXICO CHAPTER HERE
  #3 (permalink)
Old 05-10-2008, 09:43 PM
dfishrmn88's Avatar
I have been running the Edge on lvl 2. Doesn't that tend to lean out the mixture? I've read threads where they were running too lean with the Edge especially with a CAI. I am stock as far as the intake goes. I have had to have injectors replaced before this happened, could this linked to the problems '05s have had with injectors? Would like to recognize a potential problem before it occurs again.
__________________
  #4 (permalink)
Old 05-10-2008, 10:19 PM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
Probably that tuner...
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #5 (permalink)
Old 05-11-2008, 01:07 AM
dollar dee is starting off with a positive reputation.
how do u know when the converter goes out
  #6 (permalink)
Old 05-11-2008, 12:24 PM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
Leaning out will overheat the cat, especially if it is lean enough to cause a misfire. The tuner is likely the cause of the failure. Most the tuners actually add more fuel, not lean them out. Tell me, is this one of those $20 chip mods that you can get on eBay? Running rich or misfires is the most common cause of failures. You should take this up with the maker of the tuner.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDry filter
  #7 (permalink)
Old 05-11-2008, 12:52 PM
Your best bet is to get a scanner to check air/fuel mixture. Check it with the tuner on different settings. Make sure the tuner is the cause of the problem, and not something else.
__________________
  #8 (permalink)
Old 05-11-2008, 01:44 PM
dfishrmn88's Avatar
Quote:
In my case the engine would knock under acceleration @ 3200-3400 rpm. Also mileage was dropping and always felt like the engine was working too hard.
__________________
  #9 (permalink)
Old 05-11-2008, 01:51 PM
dfishrmn88's Avatar
Quote:
The tuner is the Edge running lvl 2, adjusting shift firmness up slightly, idle up +10, and WOT fuel at 1.40, no other changes. I don't run it with a real heavy foot but it did misfire once accelerating to enter highway.
The Edge has only been on the truck for 6000 mi.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
