5.8 oil cooler/radiator hose - Ford Truck Enthusiasts Forums
Old 06-10-2000, 04:17 PM
ppoel ppoel is offline
ppoel is starting off with a positive reputation.
Anybody have an idea where I can obtain the correct lower radiator hose for my 1995 Bronco, 5.8L, Auto, with trailer tow package? There is a tee in the main hose with a feed and return that goes to a factory oil cooler attached to the block at the oil filter base. Non or the parts shops have the CORRECT hose for this application. I know the cooler is OE because I ordered and took delivery of the truck new. Thanks!
Old 06-12-2000, 11:17 PM
Katt Katt is offline
Katt is starting off with a positive reputation.
If you can't find it at a parts store, you can always get it from your local Ford Dealer. It'l cost more, but ya gotta get what ya gotta get.
Good Luck
Old 06-13-2000, 06:32 PM
Yup I found out the only place to get it in my area id the dealer. Sure wisg it came with a jar of vasoline. Turned out to be $99 out the door!
Old 06-20-2000, 08:14 PM
78F100 78F100 is offline
78F100 is starting off with a positive reputation.
Can you get a new standard hose, cut it and attach each piece to the tee fitting? Or is the tee molded rubber? Maybe you can use a copper tee from the hardware, with short pieces of pipe sweated in to attach the hoses to.
Old 08-06-2000, 10:35 PM
This may be a long shot. But, back in '72,'73 I remember seeing new 429 police intercepters coming down the assembly line with a oil to water heat exchanger similar to what you describe. The parts may be available from the auto parts stores for these. These were 1972 & 1973 Ford Galaxies or Customs (I don't remember which). I do remember that they were fast compared to standard LTD's. One other unrelated thing, they had hydraulic brake boosters (hooked up to the power steering pump, no vacuum booster).
Old 08-07-2000, 09:21 AM
gypsybill's Avatar
gypsybill gypsybill is offline
gypsybill is starting off with a positive reputation.
1995 F150 XLT 5.8L and oil cooler question Mad_Max_F150 1987 - 1996 F150 & Larger F-Series Trucks 3 06-29-2014 05:21 PM
1996 351W Bronco - oil and oil cooler 3speed Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 18 04-13-2013 08:43 AM
do i have an oil cooler ssquints999 1987 - 1996 F150 & Larger F-Series Trucks 12 01-28-2009 07:51 PM
Lower radiator hose ppoel 1978 - 1996 Big Bronco 9 11-05-2001 11:37 AM
Radiator Hoses JoeB 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 09-19-2000 11:37 PM
Tags
1995, 58, 58l, 60, blockage, coller, cooler, f150, factory, ford, hose, lower, oil, ppoel, radiator, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
