Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-10-2008, 03:51 PM
taylorjgreen is starting off with a positive reputation.
65F100-How To Determine Transmission Model
I have a 65F100, automatic with a 352. How do I know or determine what model number the transission is?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-12-2008, 07:03 PM
85e150six4mtod has a good reputation on FTE.85e150six4mtod has a good reputation on FTE.
Cruise-0-matic, an improved model of the Ford-o-matic. C6 came out in '66, FMX later. If your trans was replaced, it could be the later ones.
Is it all cast iron, cast trans with aluminum bell, or all aluminum?
  #3 (permalink)
Old 05-13-2008, 03:39 PM
NorminN.B. is starting off with a positive reputation.
Found this on this site. Ford Transmission Spotter's Guide .: Articles
  #4 (permalink)
Old 05-13-2008, 07:30 PM
Quote:
Originally Posted by NorminN.B. View Post
Thanks for the help. 65 is a C4
  #5 (permalink)
Old 05-14-2008, 12:07 AM
Not a C4 behind an FE in a pu. Cruise-0-Matic. I know, they called them all Cruise O Matic, but the COM is bigger than the C4.
Look at the notes for the C4:
C4 bell housing is removeable, C6 is not.
Rectangular, almost square pan ( 10" X 9") with slight buldge on front pass. corner. Pan has 11 bolts.
5.0L engines tended to have C4s not C6s.
Not an overdrive tranny. Fairly robust unit. Can take a fair amount of power. Eats about 60 less HP than a C6. ""
Now look at your trans and pan.....
  #6 (permalink)
Old 05-14-2008, 08:54 AM
stuart1 is gaining momentum as a positive member of FTE.
Like was stated.
Not C4.
That list does not show cast Cruiso's at all.
Yours will be a cast iron CruisOmatic and could even have a cooler mounted close to the transmission vs in the rad.
__________________
Transmission builder since 1964.
2002 Ranger.
3.0 engine.
  #7 (permalink)
Old 05-14-2008, 09:45 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
Quote:
As original.
1965/67 F100/350 with a 352 uses MX Cruise-O-Matic only.
1965/67 F100/250 with 240/300 uses a C4.
1965/67 F350 with 240/300 uses MX Cruise-O.
No C6 transmissions in F Series trucks till 1968.
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
