Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-10-2008, 02:56 PM
Hydroburke is starting off with a positive reputation.
5.4 no power @ high RPM
Hi, new to the forums, looks like a good place to be
I have a relatively simple question that I just want confirmed before I buy a replacement part.
2005 F-250 Super Duty, 5.4 gas.
My truck falls on its face when going into passing gear, it actually slows down. I've got 3 engine codes P0191 fuel rail pressure, P0171 bank 1 too lean and P0174 bank 2 too lean.
The truck is also hard to start after re-fueling, but starts like a champ any other time.
I changed the fuel filter and nothing changed, so I'm assuming a fuel pump. Now, before I go out and buy a new fuel pump I figured I'd check to make sure it's not something else that would make me say "D'OH" after changing the pump.
Another question would be where to buy a fair priced fuel pump
Thanks
  #2 (permalink)
Old 05-11-2008, 09:18 PM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
You need to drive it with a fuel pressure gauge hooked up. Either the filter is clogged or the pump is weak.
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 05-16-2008, 09:32 PM
F250Gasser is new and has a neutral reputation at this point.
Do you have a K&N filter, my 04 250 5.4L ran like crap because of an MAF sensor problem. It had the second two codes you mentioned, just at thought of something else to check.
  #4 (permalink)
Old 05-22-2008, 07:00 PM
99_F250_SD is starting off with a positive reputation.
f250gasser- was your truck hard to start to when you had the K&N?
  #5 (permalink)
Old 05-23-2008, 07:46 AM
It was a little, my MAF wasn't that bad. I just noticed the lack of power/mileage that the truck had at one time. The ford performance shop I took it to said they see it happen alot from over oiling the filter when its cleaned.
  #6 (permalink)
Old 06-15-2008, 07:59 AM
elmo8641 is starting off with a positive reputation.
it sounds like a fuel pump to me. if you have a scanner you can see your fuel pressure on the data list. if it is low and you already changed the filter, then that would be the next logical step. low fuel pressure will cause the lean codes too.
__________________
2003 f-250sd 4x4 4.10 5.4L
1994 cobra w/ trickflow heads, 10lb turbo
  #7 (permalink)
Old 06-15-2008, 08:40 AM
galaxie641 is starting off with a positive reputation.
I'd also suspect the fuel pump. Do you happen to run the truck way low on fuel before you refuel it?
__________________
'48 F1 Flat6
'51 F3 Flat8
'64 Galaxie 352 4bbl
'68 F150 390
'72 F250 400/C6
'97 F150 5.4L
  #8 (permalink)
Old 06-16-2008, 02:00 PM
FTE/PARTS-GUY's Avatar
FTE Sponsor
FTE/PARTS-GUY is gaining momentum as a positive member of FTE.
i'll hook you up on a pump if you need one.
Ed
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
