Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-10-2008, 01:22 PM
oldtruknut is starting off with a positive reputation.
Whats the easiest way to determine distributor
What are some ways to determine what kind of distributor I'm looking at. I have several different distributors. Do the windsor series engines have a different amount of teeth on the sprocket then the cleveland and the other big block distributors
  #2 (permalink)
Old 05-10-2008, 04:18 PM
mark a. is gaining momentum as a positive member of FTE.
I've never counted teeth but the small blocks have a noticably smaller gear than 335's or 385's.
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 05-10-2008, 05:07 PM
unrulee's Avatar
unrulee is starting off with a positive reputation.
The drive gear on the Windsor engines is different form the 335 series of engines. If you swap gears on a Windsor dist with the gear from a 335 series you can use it in a 335 engine.....and that works the other way as well.
__________________
Lee
STGs Minions - Frozen F-Series
1979 F250 Ranger 4x4, where to start? lots of stuff added!!!
2005 F250 Lariat FX4, SCREW, 6.0 PSD, making progress
"Instruction manuals are nothing more than another man's opinion."
  #4 (permalink)
Old 05-10-2008, 07:35 PM
80broncoman is starting off with a positive reputation.
221-302 uses one dist, 351W another (Different oil pump driveshft dia). same gears
All 351C, M, 400, 370-460 use the same fitment.
__________________
Real men don't wear Bowties
  #5 (permalink)
Old 05-11-2008, 06:53 PM
danlee's Avatar
danlee has a good reputation on FTE.danlee has a good reputation on FTE.
The oil pump shaft on a 351W, 351C, 351M, 400, 429, and 460 is larger than a 289, or 302. The 351C through 460 use the same distributor and gear, but a 351W uses a different gear, You can swap a 351W distributor into a 335 series or 385 series by changing the gear. I am using a TFI dist. made for an EFI 351W in my EFI 400 with the 335 series gear.
You can't swap a 289 or 302 dist with the others unless you change the whole shaft.
__________________
JOIN THE DELAWARE CHAPTER, CLICK HERE
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
