What are some ways to determine what kind of distributor I'm looking at. I have several different distributors. Do the windsor series engines have a different amount of teeth on the sprocket then the cleveland and the other big block distributors
The drive gear on the Windsor engines is different form the 335 series of engines. If you swap gears on a Windsor dist with the gear from a 335 series you can use it in a 335 engine.....and that works the other way as well.
__________________
Lee STGs Minions - Frozen F-Series
1979 F250 Ranger 4x4, where to start? lots of stuff added!!!
2005 F250 Lariat FX4, SCREW, 6.0 PSD, making progress
"Instruction manuals are nothing more than another man's opinion."
The oil pump shaft on a 351W, 351C, 351M, 400, 429, and 460 is larger than a 289, or 302. The 351C through 460 use the same distributor and gear, but a 351W uses a different gear, You can swap a 351W distributor into a 335 series or 385 series by changing the gear. I am using a TFI dist. made for an EFI 351W in my EFI 400 with the 335 series gear.
You can't swap a 289 or 302 dist with the others unless you change the whole shaft.
__________________ JOIN THE DELAWARE CHAPTER,CLICK HERE
