Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #46 (permalink)
Old 05-16-2008, 11:11 AM
rungunner is starting off with a positive reputation.
Miles
1997 7.3 with 232.000 miles. Changed front brake pads at 221.000 miles and the rotors are still in good shape, changed rear last week at 232.000 miles and the drums are still good and the shoes were not that bad. Changed the turbo at 230.000 miles. Two front ends (tie rods and drag links, ball joints. Both gas tanks rusted through. Had the roof re-painted due to rust. Both wheel wells rusted through above wheels. Both front shock mounts broke when it was fairly new. 1 new starter. The trans in going although it would go into a limp mode for the past 140.000 miles in which I would just re-set the computer and it runs good again. Both auto hubs went and re-placed with manuals. 1 fuel filter assembly. New exaust system. Goes through shocks quickly. 5 sets of tires. The transmission and Turbo went before my rear brake shoes went, Ask me if I will buy another Ford truck ? Oh I forgot one, the front drive shaft coming out of the transfer case has a bunch of slop in it (bearing) and I do not use 4 wheel drive but maybe 4 or 5 times a year.
  #47 (permalink)
Old 05-16-2008, 12:07 PM
FFemt5287 is starting off with a positive reputation.
Quote:
did you buy that truck new? if not the PO beat the daylights out of it.
__________________
1997 F-350. 7.3l PSD. zf5. 4.10 l/s. 4x4. Single cab/8ft bed. SRW. Boost/pyro. 4" straight stacks w/ raincaps. 160cc injectors. D66 turbo. TW chip. ValAir ceramic clutch. FPR shim. 6637 filter. 140,000mi.
ORDERED: BDP 140v IDM
NEXT: 230cc inj, head studs, IC, N20.
  #48 (permalink)
Old 05-16-2008, 04:11 PM
New
Yes I did buy it new and I pull a boat and pickup camper, Motorcycles, trailers and drive all over Michigan. I did not beat the crap out of it, in fact besides a few rust spots the truck still looks great. I am 50 yrs old and have been through allot of trucks in my life so just say I have learned my lessons with my previous trucks. The problem is that I live and travel on dirt roads every day and they can take there toll on any vehicle. I do not park in a garage and I do not drive around the city. Matter of fact I can not wash it from December to the end of April because it is useless, i would be at the car wash every day. Every spring I cleaned every inch of the truck. The truck has been taken care of the entire 232.000 miles. It has had lots of problems and judging from this web site so have allot of other Ford truck owners.
  #49 (permalink)
Old 05-16-2008, 04:52 PM
Robbgt's Avatar
Robbgt is gaining momentum as a positive member of FTE.
Hey man, considering the mileage that doesn't really sound that bad!!! So no major engine problems? (other than the turbo?) I'd say you got a solid truck there. All the other stuff you mentioned will wear and break eventually. Have you been happy with it? Will you buy another Ford someday?
-Robb
__________________
97 F-350 XLT 4x4 PSD, E40D, 3.55's, 153K, 6637, 140V IDM, HPX, FPR Shim, Hotfoot, Tymar DP, Dual Exhaust, T/C Lockup mod, new GP's, Stancor GPR.
>>FOR SALE: FTE Classifieds<<
  #50 (permalink)
Old 05-16-2008, 09:22 PM
luthrobediesel is starting off with a positive reputation.
335000 on my 97 ranger sorry for not having a psd
  #51 (permalink)
Old 05-16-2008, 09:30 PM
c00nhunterjoe's Avatar
c00nhunterjoe has a good reputation on FTE.c00nhunterjoe has a good reputation on FTE.
on a ranger??? it must be a 3.0
__________________
97 F-250, 4.10's Auto, Superchip, All mods by c00nhunterjoe's performance shop http://community.webshots.com/user/c00nhunterjoe
http://youtube.com/c00nhunterjoe
  #52 (permalink)
Old 05-17-2008, 01:26 AM
884x4broncoII is starting off with a positive reputation.
215000 aprox, i should look im in my truck right now in a flying j
__________________
96 f250 7.3L powerstroke
5spd manual
4.10 axel ratio
extened cab long box
superchips max tuner
6637 filter
no kitty
  #53 (permalink)
Old 05-17-2008, 07:28 AM
Ford
Robb,
I love Ford trucks, they have been the only truck I have ever owned. Like I said things started breaking within the first 60.000 miles. Some of the things the Ford dealer has done make me want to try a different brand next time. Last August they installed an exaust system and beat the crap out of the downpipe, they just re-placed the cam sensor on a recall and did their 50 pt inspection and told me the back brakes were good, how did they know that without pulling the drums, they changed the entire fuel filter bowl for a simple problem. But the biggest complaint I have is the transmission, It has been acting up for 130 000 miles and of course Ford told me they had to pull it for $2500.00 to solve the problem. Thanks for letting me vent.
  #54 (permalink)
Old 05-17-2008, 08:55 AM
Robbgt's Avatar
Robb,
Hey everyone needs to vent now and then!
So it almost sounds like 2 things are going on here, some issues with the truck early in life, and the Ford dealer not really doing an adequate job working on your rig. I've never been a fan of ford's repair department, although it seems to be a roll of the dice! There are a few X-ford techs floating around on the boards here who I would have no problem wrenchin on my truck. Some of the Techs however may not be as educated as well (I'll put it nicely I guess...). As for the trans, the E40D is comparable to a Box full of gravel. The 4R100 isn't anything to write home about either. Thats was Ford's one BIG hickup in these trucks is putting a slush box trans behind a powerful engine. Well I'm glad that your still a ford guy for now. Good luck with the truck!
-Robb
__________________
  #55 (permalink)
Old 05-18-2008, 09:35 AM
Joe_D is starting off with a positive reputation.
36,423 original miles.
__________________
96 F350 4x4 XLT 7.3 PSD 36,507 orig miles, Tymar intake, Banks intercooler, downpipe, guages, TW 4 position chip, c00n accumulator body mod, Ford 08 aluminum diff cover, Oil guage mod, Exhaust brake, Rhino liner
It is better to have a lobster on your piano than a crab on your organ
  #56 (permalink)
Old 05-18-2008, 09:44 AM
txevt is starting off with a positive reputation.
414,*** on mine. oh, and fyi digital odometer will not go past 399,999.9 it rolls back to 300,000.0....
  #57 (permalink)
Old 05-18-2008, 11:19 AM
jboard's Avatar
jboard is starting off with a positive reputation.
Just clicked 327,000 miles yesterday.
__________________
1997 F250HD Auto 4X4 3.55 327,000mi
3X4 DP,5 inch exhaust,6637 filter,Hypertech Prog,1.0 exhaust housing,superduty comp wheel.
  #58 (permalink)
Old 05-22-2008, 04:07 PM
LongJim's Avatar
LongJim is starting off with a positive reputation.
1996 F250--135*** owned since 95K.
  #59 (permalink)
Old 05-22-2008, 11:42 PM
444dieselrod is starting off with a positive reputation.
285,8xx. on the '97.
Still on the original trans.
'96 has various engines/trans so it doesnt count.
Diesel Rod
__________________
MY Trucks...
'97 F250, 90 LED's and 5" stacks, among other things....
'96 F250 5" turn out stacks and a bunch of other ugly crap on it.
359 Peterbilt SHORT HOOD. 425 Cat, 13 speed Eaton. Corvette Dash, 17 gauges, dual stacks, 63" flat top sleeper,---->36" sitting here waitng for paint. 1.296 Million Miles. going Broke paying $4.06 for Diesel.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
