Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-10-2008, 09:52 AM
craig at ojo is starting off with a positive reputation.
thunderbird 429
I just spent a day digging what's supposed to be a 68 Thunderbird 429 out of a friends shed. I have been told that the heads on this Engine will really improve the performance of a 460. The casting numbers on the heads are C8VE-E. Can anybody tell me about these heads? are they a good performance swap? I also have heard that the 429's are a lot better on gas than the 460's. any comments?
Thanks
Craig
  #2 (permalink)
Old 05-11-2008, 04:11 PM
darrin1999 is starting off with a positive reputation.
the reason theyd improve performance is because theyll raise your compression... if you have d3ve heads they have big chambers (95-99cc) and the c8ve heads have small chambers (72-77 cc) turning the stock 8.5ish-1 compression to 10.5ish-1 the reason i say -ish is because chamber volume on factory heads will vary a bit. the heads actually flow almost exactly the same. thats also the main reason they get better mileage- higher compression means better efficiency- up to the point of detonation. the 31 ci displacement difference doesnt make that much difference in mileage because what they were installed in was big and heavy... if you install a 429 and a 460 in a big heavy vehicle the mileage could be the same or slightly worse with the 429... if its a lighter vehicle then the 429 would win out on mileage... with a heavy vehicle you need more torque and thats what displacement gives you.
__________________
drive trane parts may strand you, but suspension parts can kill you.
if you cant pay cash for it, you cant afford it.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
