Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-10-2008, 03:30 AM
stealth1's Avatar
stealth1 is starting off with a positive reputation.
360 intake upgrade
O.K fellas I need advice on swapping out my 2bbl for a new intake and 4bbl. What is a good combo to go with and really don't want to break the bank. I'm currently taking the engine apart to clean and just decided to scrap the old intake and carb. Thanks
__________________
2002 F-250 CC 4x4 PSD
Edge Att. w/monitor
4" magnaflow
AFE stg.2
4" lift
33" BFG mt"s
All Fosgate audio
05 Badges
2002 Stang GT. Convert. Stock for now.
1971 Camaro Stock for now. Gone baby...
1974 Ford F-250 4x4 S/C ,
  #2 (permalink)
Old 05-10-2008, 04:37 AM
johnboy427's Avatar
johnboy427 is starting off with a positive reputation.
I had an Edelbrock street master on my 68 with a 390 it was a great intake I picked up at a swap meet for $50 and the carb was just one of the cheapo holley 600s but it made a huge difference and for under $300. Tons more power and a little better milage, if you have an automatic you need to make sure it is compatible with the kickdown linkage. You will hear a lot about holley vs edelbrock carbs I feel like is a matter of opinion both have goods and bads. I would just go with dual plane intake designed for low end touque and a carb of 650cfm or smaller. All of this is assuming you motor is currently stock.
-Johnboy
__________________
-1979 F-250 4X4 400 4spd
-1989 Bronco 300six swapped in ZF 5spd
-1967 Mercury Comet Sports Coupe
  #3 (permalink)
Old 05-10-2008, 05:28 AM
hoxiii's Avatar
hoxiii is gaining momentum as a positive member of FTE.
If you just want more pep on a stock motor I'd toss a factory iron 4bbl intake on it with a 600ish CFM AFB and call it good. It'll be like night and day and all for about the $300 that was mentioned (and that's if you buy a NEW carburetor). Pick up a used one and you can do this for $100.
Justin
__________________
86 150 SuperCab Shortbed 4x4 conversion XLT Lariat, 300, 435
85 150 4x4 convert, 390 FE, NP435, 205, 9" TTB 44
R.I.P 8-26-07
http://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=161169&.jpg
  #4 (permalink)
Old 05-10-2008, 02:16 PM
fastfarmer is starting off with a positive reputation.
I agree with the factory cast iron 4bbl intake, they flow just as well as an Edelbrock Performer, just heavier.
__________________
  • 76 F150 Ranger 2wd 352 4sp
  • 91 F250 XLT Lariat 4X4 7.3 E4OD
  • 97 F250 Heavy Duty XL 4X4 351 5sp
  • 99 Mustang GT 4.6 E4OD
  #5 (permalink)
Old 05-10-2008, 10:17 PM
docholiday72tx is starting off with a positive reputation.
The guys that are suggesting putting on a factory cast iron intake must have never installed one with the motor in the truck. Chances are very good you can't install one with the engine in the truck unless you turn green and pop out of your clothes when you get mad.
All that aside, I've run the cast iron, and dual plane aluminum on 360/390's and I saw very little if any difference as far as performance.
__________________
If it ain't broke....oh wait...it is
  #6 (permalink)
Old 05-11-2008, 01:23 AM
78f-150Supercab's Avatar
78f-150Supercab is starting off with a positive reputation.
Yeah, installing a cast iron intake is a PITA. Go aluminum. Save some weight. Makes installation much easier and your engine lighter. A lot of people toss aftermarket aluminum intakes on their engines. I've seen a few on junkyard motors. Shouldn't be too hard to find one on the cheap.
People always look for ways to squeeze out a few more HP. Shave off some weight and you won't have as much to lug around. It's not that big of a difference in the overall scheme of things, but every little bit helps.
  #7 (permalink)
Old 05-11-2008, 01:36 PM
hoxiii's Avatar
Quote:
Nah, done it more than once and I'm 140lbs of "hulk"
The idea is to work smart and not hard, so I use an engine hoist with a lift plate that bolts to the carb pad.
Justin
__________________
R.I.P 8-26-07
  #8 (permalink)
Old 05-11-2008, 01:48 PM
Yeah, but all you need is your arms for an aluminum intake ;-) and not everyone has a hoist.
  #9 (permalink)
Old 05-11-2008, 02:01 PM
hoxiii's Avatar
I'd call it a good excuse to buy a hoist. It's 285.95 for a performer through summit. Take $50 of that to buy an iron manifold and gasket set and teh other $230 to buy a hoist.
mmmm. . . . I love my logic, it gets me new toys.
Justin
__________________
R.I.P 8-26-07
  #10 (permalink)
Old 05-11-2008, 03:20 PM
Justin
I want to be just like you when I grow up.
I never thought about the engine hoist, but then again the weight of cast iron versus the weight of my 140 pounds was one of the selling points with my wife in order to score an edelbrock manifold.
__________________
  #11 (permalink)
Old 05-14-2008, 12:56 PM
stealth1's Avatar
The truck is a standard. Thanks for the info. Guess I'll start making some calls to see what I can come up with. Don't really care about the weight so if the iron is alot cheaper I may go that way. Doing alot of little things to the truck so every penny helps.Thanks again....
__________________
Edge Att. w/monitor
4" magnaflow
AFE stg.2
4" lift
33" BFG mt"s
All Fosgate audio
05 Badges
  #12 (permalink)
Old 05-14-2008, 01:43 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is starting off with a positive reputation.
Cast Iron can be found in PYP all day long. But 1/2 price day is the best time, sometimes I go and pull what I want then hide it till the sale
Be aware there are port matching issues though. If you get one off a old Tbird or ? early sixties you mayer have huge ports on the intake vs the heads.. no so bad when the other way around.
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #13 (permalink)
Old 05-14-2008, 03:10 PM
mattri is starting off with a positive reputation.
I have a 4bbl intake, casting code c6ae in good shape. Pm me or send me an e-mail matt_ h_ ritchie @ yahoo . com
  #14 (permalink)
Old 05-14-2008, 05:00 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
Look for an iron manifold with an "S" ot s "T" on one of the front runners. It will have the new improved ports that will fit properly.
__________________
Bear 45/70
Gimp Racing
Don't pick a fight with an old man. If he is too old to fight he will just kill you.
  #15 (permalink)
Old 05-15-2008, 08:51 AM
stealth1's Avatar
I'm a dummy, whay is PYP?
__________________
Edge Att. w/monitor
4" magnaflow
AFE stg.2
4" lift
33" BFG mt"s
All Fosgate audio
05 Badges
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
