Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-10-2008, 03:24 AM
jamies460 is starting off with a positive reputation.
Question Ford Racing Single Plane Intake ???
Hello, I am trying to find out if the Ford Racing single plane intake ( part M 9424 H429 ) will bolt up to my Edelbrock 61649 Cobra Jet heads ? And if the ports on the Ford racing intake are the same size as the ports on the 61649 heads, no port matching needed. Just bolt up and go, ( As Victor intake 2965 has small ports and need to be opened up to match the 61649 heads ) Thanks Jamie.
  #2 (permalink)
Old 05-10-2008, 08:48 AM
Bern_F150_4x4 is starting off with a positive reputation.
I would contact Edelbrock directly; they have good tech support.
__________________
'85 F150 4x4 300CID, NP435, 3.08's, Factory 15x8's, 31" Goodyears, Lock-Right in the back.
'86 F250 Supercab 4x4HD, 460 4V, T19, D50/Sterling 10.25 Trac-lok, 3.55's
FTE, yet another reason to have a networked PC in the garage!
The other side of green...
  #3 (permalink)
Old 05-10-2008, 10:50 PM
Hello Bern, I am in Australia.... a bit expensive to call Edelbrock ! As I found the Ford Racing intake on the web, it states for Ford Cobra Jet and Production heads ??? As I do not want to order it and when it arrives find out it has the small ports and not the large Cobra Jet ports to match the 61649 heads. Thanks Jamie.
  #4 (permalink)
Old 05-11-2008, 08:47 AM
jwtimme is starting off with a positive reputation.
most of the large single plane intakes come with smaller ports so that you can match them to your heads. This is because about 99 percent of people running these intakes port their heads and intake.
  #5 (permalink)
Old 05-11-2008, 09:04 AM
Quote:
I have emailed them regarding their AL 460 heads in the past and always got a quick response. Cheap solution for ya.
Hey, OT, how much is gas down there? We are $3.70/Gallon in Maryland, USA.
__________________
  #6 (permalink)
Old 05-12-2008, 07:04 AM
Hello, Fuel prices down here in Australia are currently around $1-45c a litre, But I have seen some petrol stations selling fuel for $1-52c for standard unleaded. The Premium unleaded sells from around $1-57c up ..... its roughly about 10 to 12 cents a litre dearer than the standard unleaded. I think I will stick with the Victor intake and just open it up, Thanks Jamie. ( I have emailed Edelbrock in the past but never had a reply.... I have the Victor 460ci water pump, Cobra jet 61649 heads , victor Intake... hopefully there tech help is a bit better over there ? )
  #7 (permalink)
Old 05-12-2008, 09:41 AM
werneil is starting off with a positive reputation.
hi jamie, i have replyed to your site previously, but for other reasons have not been back
on site for a while, sorry for not running a dyno program on your motor , with cam specs,
valve size, carby cfm, exhaust primary diameter, collector diameter, intake design, etc.
i will try and run the program for you
ps most manifolds require some port matching
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
