Shift Indicator
Sounds like the cable is broken or disconnected. I through up some pics for you. If you have to change it, it is not too difficult a job.
Cluster removed: (I use a 1/4 nut driver to removed the 2 screws holding the indicator to the guage assembly:
This is the end that connects under the sterring column cover (only 1 screw to remove the column cover:
This is the back of the shift indicator:
Hope this helps. Sometimes the plastic tubing that the small wire runs through cracks up too.
on
I wonder if the hard plastic emissions tubing that they sell at auto parts stores would work? It's a similar diameter, it's hollow inside (of course), and it's flexible.
I think I'll pick some up sometime and see if I can fix my old C6 indicator. I have an AOD one that doesn't work any better, since my tach cluster is out of an AOD truck.
BTW: I scored one for an AOD truck, but I have a C6. Anyone want to trade? It has to work though.
Shadowrider123
02-27-2016 09:48 PM
blueovalboy86
06-07-2005 09:18 AM
