Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-09-2008, 11:39 PM
Wynn96 is starting off with a positive reputation.
Truck won't start
96 f150
4.9
93xxx miles
m5od
dual tanks
First off, my front fuel pump is weak, back one works great.
Truck would start fine, then it would not start again when I shut it off, unless it sat for a long time. Then it died on me while driving. Towed it home, started up in the driveway.
I went and got a new module, the one on the fender. Truck started fine. Problem solved? Nope, it died at the hardware store, and it would not start even after sitting there all day. Went and got a new cap and rotor. No luck. Got a new pickup coil, still no luck. The whole damn ignition system has been replaced, and I am still not getting spark. I pulled a plug so I could watch for it to spark, but nothing. What else is there to check? I'm already in it for $150 with no luck
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-09-2008, 11:48 PM
JJ98 is starting off with a positive reputation.
hay jut a quick one not to insault you at all did u check the fuses under the hood allso the wires for the coil pickup and the battery voltage to the coil just a thought also check and see if anything is coming out of the coil if so then it could be a bad wire or a control mod on the coil uless u changed that to also for the fuel thing check the inertiafuel cut off switch could have be kick or something
  #3 (permalink)
Old 05-11-2008, 02:31 AM
Thanks for the suggestions. I went out and checked all my fuses, but it hasn't worked yet. I'm going to keep messing with it tomorrow. If anybody else has any ideas feel free to chime in. Thank you for your help JJ I'm hoping to get her running tomorrow so I need all the help I can get.
I'm tempted to put a for sale sign on her, but I know I'd regret it. I'll get it fixed and it'll be good for a long time again.
  #4 (permalink)
Old 05-11-2008, 02:15 PM
OldMetal's Avatar
OldMetal is starting off with a positive reputation.
If this is an on and off problem you probably have a bad wire connection somewhere and changing parts will not help unless you just happen to hit the right wire, go through your system and make sure all grounds are good and there is no corrosion on the positive sides, also pin connectors have been known to come out so be sure they are all the way in. This is time consuming but you need to be sure what you have is capable of working before guessing at what parts to change.
Happy hunting.
__________________
77 F150 4X4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
