Connect multimedia in dash player to reverse wire in dash on 2006 f150 - Ford Truck Enthusiasts Forums
Old 05-10-2008, 12:23 AM
pep100 pep100 is offline
pep100 is starting off with a positive reputation.
I have a 2006 f150 SCREW. I just bought a Valor DTS 660w. the 660 has a reverse wire. I have a Audiovox license plate backup camera.
If I can connect the 660 to the trucks reverse wire, the 660 will switch to rear camera automatically when I put the truck in reverse.
The camera is connected to the reverse wire at the hitch harness. It comes on whenever I put the truck in reverse. W/o connecting the 660 reverse wire to the truck reverse wire, I have to do manual switching on the 660.
Does anyone know where the under the dash reverse wire is located?
Thanks.
Old 05-10-2008, 04:52 PM
I am going to run a wire from my hitch wiring (same reverse wire I used for camera), and follow the camera video feed back to the DTS 660w's brown reverse wire. It should work fine. I'll post results.
Old 05-10-2008, 10:07 PM
Worked perfectly!!!
Old 05-11-2008, 03:42 PM
Actually the reverse wire is white/green not brown. the brown wire on the 660 is mute.
installing a backup camera, need to find a reverse trigger tom18287 6.7L Power Stroke Diesel 11 07-12-2015 06:12 PM
F450 2005 Reverse Light wire in harness in dash GormGorm 1999 to 2016 Super Duty 10 09-25-2012 12:24 AM
2006 Ford F150 FX4 Bolt pattern? GrizzlyMan660 2004 - 2008 F150 1 04-02-2012 10:21 AM
Reverse Lamp Circuit question dzaharias7681 2004 - 2008 F150 3 04-17-2011 09:19 PM
rear camera, reverse signal input? XHunter Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 09-01-2010 12:29 PM
Tags
2006, 2008, connect, dash, detect, f150, ford, reverse, superduty, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
