wheel bearing replacement?ball joints?
i have a 94 idi turbo and i have a noise coming fromn the front end i think it is a wheel bearing because when i put it into 4wd it sqeaks and squalls.and in 2wd when im driving it sounds like something is clacking when i stick my head out the window when im driving slow.any ideas before i just tear it apart and start looking?i havent done a wheel bearing on one of these trucks before has anyone done one on one before?are they a pain?any feedback would be awesome
I had one go out on me, i was stupid enough to try and say it was fine, but i started to feel the brake drag. after a wile i noticed that my alluminum rim started to turn black, i gave in and went to the parts store and got the new bearings ( only like $40 for the pair). when i started to tear things apart i found that my procrastination could have cost me alot more money, the weight of my pickup had ben sitting on the bottom of my rim cousing it to shave the metal of the rim as it when around. it completly destroyed my locking hub, and started to eat away at the axle stub. i had to replace the rotor too from it wearing unevenly.
To make a long story short try not to procrastinate if you thing its a wheel bearing
That sounds allot like u-joints. Check the needle bearing for the stub shaft also.
Wheel bearing on this truck is like any other vehicle. The hub nuts could a couple of different ones so the socket you will need it hard to say for sure.
Pack them good and when you adjust them don't get them to tight. A tight wheel bearing will scatter fast. When you put them on tighten the adjust nut down pretty tight. Don't turn the hub while you are doing this. Back the nut off till it gets loose then tighten it till it touches the outer bearing. Turn the hub and see how it feels. You want it to spin pretty free. When you put the wheel back on push and pull on the top of the tire. You don't want to feel any movement but you want it to spin free.
The reason you tighten the adjust nut down tight at first is to make sure the hub is seated on the spindle all the way.
After it is all said and done drive her around some. Check the hub, it shouldn't feel very warm. Test drive around where you don't have to hammer on the brakes much so you don't get that heat.
Also when you check the hub for play, make sure your calipers are in. You don't want the brake pads holding your hub for you while you do this.
I wouldn't say you are an idiot for asking a question like that.
Other things determine that.
