onelugnut:
My answer and my point is that you can probably spec a F - 450 to pull your load, but you will have such a heavy duty truck you will not enjoy the ride and economy with all the beef and reduction. From what I read that I have cut and pasted from Ford's web sites, I do not believe the F - 350 will legally pull your load, especially in KAL -- EE -- FORNIA for us Southern Boys.
Here is what I found with reference you can check:
The way I read the FORD specs, the maximum loaded trailer weight for a F-350 dually, crew cab, auto or manual is 15,000#
Similarly, for the F-450 the maximum trailer weight for a F - 450 dually, crew cab is 16,000#
Fifth wheel max trailer weights jump to a maximum of 15,200 # and 17,700# with 4.3 rears, and package.
The big jump is with the F - 450 which jumps to 17K, 18k, 20k and even up to 24K weight with certain packages and rear ends, the maximum looks like 24,500# with 4.88 rears.
Here is the link:
http://www.fordvehicles.com/assets/p...ec%20Light.pdf
Then this link makes this claim:
MAXIMUM CAPABILITIES*
F-250 16,400 lbs. 5th-Wheel Towing • 12,500 lbs. Conventional
Towing • 3170 lbs. Payload • 23,000 lbs. GCWR • 10,000 lbs.
GVWR • 6000 lbs. Front GAWR
F-350 18,700 lbs. 5th-Wheel Towing • 15,000 lbs. Conventional
Towing • 5720 lbs. Payload • 26,000 lbs. GCWR • 13,000 lbs.
F-450 24,500 lbs. New Record 5th-Wheel Towing • 16,000 lbs.
New Record Conventional Towing • 6120 lbs. New Record Payload
• 33,000 lbs. New Record GCWR • 14,500 lbs. New Record GVWR
• 6500 lbs. New Record Front GAWR*
http://www.fordvehicles.com/assets/p...%20Cat_NAV.pdf
REMEMBER when you read the "fine print" to see that you should always check with your sales consultant. (i.e. YEAH, right, my bet to sell a truck today, they will tell you a F -350 will pull doubles!!!!!!!!!!!)
