Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-09-2008, 08:58 PM
datafive0 is starting off with a positive reputation.
Passanger window stopped
Hi all, I am a newbie here but have had quite a few ford. This is my first explorer, I got it in 2000 and it has served me well with no complaints till lately.
History, the passager window motor was replaced in 2003. The starter was done last month. It has has all new brakes and lines in 2000. The resaon I got it so cheap is the last owner (elderly man) put power steering fluid in brake master cyl.
So for the last few weeks the window (front passanger door) has been working on and off. Well 4 days ago it quit totally. Unlike the last time I cannot afford to have someone fix it... because I was part of a "cut back" so I am out of work..
So my question is, do I need to replace the motor or relay or am I looking for something else?
If I need to replace it can someone point me in the right direction or a link with pictures.... anything that will help.
Thanks in advance, Aaron
  #2 (permalink)
Old 05-12-2008, 07:46 PM
eallanboggs is starting off with a positive reputation.
Ford uses plastic planetaries. I remove the motor and open it up. Remove the plastic planetaries. Take a 5/16" hex head bolt with a long shoulder. Cut 3 sections out of the shoulder area of the bolt 1/2" long each. Drop the little pieces of bolt in where the plastic ones came out. Add some grease and reinstall. It will work forever and you just saved $200.00 on the cost of a new motor for the motor at the dealership. They used to sell a rebuild kit of this problem, but they stopped because they make more money selling you an entire new motor(which you don't need) instead of the repair kit. I've done plenty of these on Expeds, Explor and Lincolns. They all have plastic planetaries. Don't tell anyone about my idea! It's a secret.
  #3 (permalink)
Old 05-12-2008, 07:59 PM
beater79's Avatar
beater79 is starting off with a positive reputation.
you can also check at your local auto parts store. they are usually only around 60.00 for the motor. dont go to a dealership, I work at one and dont even buy parts there, even with my "discount" they still rape ya for the same part u get at the locals. It sounds like the motor is bad, they do go out fairly easy, make sure the connectors are all dry, that has been the biggest cause of them quitting, water runs down the window and doesnt get routed away from the motors.
__________________
79 F-150 short bed, 400m, 4spd, 4x4, 4" rancho lift
96 explorer 4.0 auto, k&n filter, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
