Anyone have MII rack being to short problems?
I put in my MII frontend a few weeks back and found the rack was about 4" to short for the 48-52 so I bought a set of rack extensions but they were the wrong thread pitch so I was going to machine some that were the 9/16x18 I needed. In the mean time I was talking to a friend that has owned and or built 30+ streetrods and told him the problem and my fix for it. He told me the granada outer tie rods were longer so I got one today to try it and sure enough they will fix the problem. I should have the second one Monday so I can get the frontend turning with the steering wheel, it will be almost like a real truck.
I thought this might help someone else out
Mike
Mike
I bought the speedway crossmember and used original MII stuff after I replaced the ball joints and bushings with a factory rack so it ends up short. Heidts and Art Morrison sell the rack extensions for power as well as manual racks so it must be a common problem but if you use the granada tie rod ends you don't have any extra things in the steering to come loose/break etc.
Mike
Mike
Mike, if you use the longer outter tie rod ends rather than spacing the inners, you'll likely have a bump steer problem. You want the inners to pivot right in front of the lower control arm bushings, so the steering and control arm move in the same arc. Using the longer outter tie rod ends will solve your length problem, but you'll notice the inners will be inboard of the control arm bushings. The steering and control arm will then move in different arcs, steering the truck for you on bumps. Thats bump steer. The inner spacers are the right solution.
Doc
05-18-2011 09:47 PM
rtcalabrojr
75
10-30-2010 10:46 AM
rtcalabrojr
06-14-2010 10:46 PM
Michigan Rick
19
10-13-2008 05:16 PM
