Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-09-2008, 07:41 PM
felixbot is starting off with a positive reputation.
Smile 98 4.6 no voltage to cpk
I have a 98 F-150 4.6. Reconnected engine after about a year disconnected. Replaced timing set and oil pump. I have no voltage to the crankshaft position sensor. Where could i find a wiring schematic or diagram so that i could trace back to see where i am losing the power. Any help would be appreciated. Thanks, Felixbot.
  #2 (permalink)
Old 05-10-2008, 07:13 AM
projectSHO89 is gaining momentum as a positive member of FTE.projectSHO89 is gaining momentum as a positive member of FTE.
The crank sensor on your engine is a variable reluctance sensor, therefore it does not have voltage applied to it.
When the steel teeth pass the sensor element, the magnetic field of the sensor is disturbed and the sensor produces an output signal from that changing magnetic field.
Steve
__________________
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 05-10-2008, 10:23 PM
re; no voltage vat ckp sensor
it says in my haynes manual to remove harness from sensor and check for voltage at plug with key on. it cannot produce a signal without some kind of input signal.
  #4 (permalink)
Old 05-11-2008, 08:27 AM
A correction:
With the ignition in RUN, you should see 1.0 - 2.0 VDC at both terminals of the CKP sensor. This is a bias voltage.
If the voltage is not present, either a short-to-ground in the CKP circuit exists, an open in the CKP circuit exists, the PCM is missing an input voltage (does the CEL come on during bulb proveout?), or the PCM has a defect.
Start with checking the CEL lamp, you might be troubleshooting the wrong end of the circuit.
Steve
__________________
  #5 (permalink)
Old 05-15-2008, 05:22 PM
The cel comes on but goes off after a few seconds. There are no stored trouble codes in the system. When trying to start for the first time, I plugged in the Engine harness but did not tighten the bolt that pulls it together. in my initial frustration, I tightened the bolt while the key was on. Could I have blown the computer? The engine was out for about a year so its possible the terminals in the main connector could be dirty or corroded. I will check that next.
  #6 (permalink)
Old 05-21-2008, 04:49 PM
I found the problem. The engine builder did not install the crankshaft sensor tooth wheel when reassembing the engine. I removed the front cover and installed the missing wheel and when reassembled it started right up. Thanks to everyone for their help.
Felixbot
  #7 (permalink)
Old 05-21-2008, 05:13 PM
LOL!
That's a good one! Hope you let the builder know how much fun he caused you.
Steve
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
