Has anybody put an aftermarket tranny cooler on their X and bypassed the stock cooler? Is it a good upgrade? I have no problem with temps but I thought it might be a good upgrade as long as it was big enough with its own fan.
It's my understanding that the stock 6.0 tranny cooler is the biggest/best there is. Never heard of someone replacing it.
Could be wrong though.
RoyC
+1....
the stock 6.0l tranny cooler is very hard to beat...
__________________
William
Southern Nevada Power Strokes.Org
04 Eddie Bauer Excursion w/03 6.0l PSD/ARP's
4" MBRP T-409 SS exhaust/straight piped
4 gauge A-pillar w/DiPricol Optix boost, pyro,
fuel pressure, and trans temp
SEIC Mod
Infinity door speakers and Alpine amps and subs
Ride Rite air bags and Hellwig rear bar
Train Horns
27' 05 WW FS2600 Toy Hauler
I have noticed that the tranny temps come up to operating temp very quickly. In my oldchevy suburban I had a 14 pass 28,000 lb cooler w/fan and the tranny never got hot and stayed very close to 180 degrees. I don't know much about the 6.0 setup yet, but I am learning. I do not want to hurt the engine , especially with the problems it already has built into it, ie, head gasket, turbo, cooler.
Ian, do you have an aftermarket gauge or the Ford Idiot gauge?
__________________
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system and Van Turbo. Bilstein Shocks with U code front and A code Rear.
__________________
No, fluid fine. Just never saw the tranny temp come up so quickly before. The X only has 47K on it and no problems. Just trying to play devils advocate and worry before something does go wrong. I am a little paranoid since I also have the 6.0 in her. I keep hearing war stories about the engine and thought it might run over to the tranny. I am glad it doesn't. Thanx for the help!
I still think you are worrying about nothing. When you have the aftermarket gauge we can speculate a little better.
__________________
The only thing I don't like about the X tranny cooler is that it is sandwiched between the AC condenser and the IC. My Suburban 6.5L TD had both the engine oil and tranny coolers out front of the AC condenser. Just seems to make more sense. I had 200,000+ miles on the Suburban with synthetic tranny fluid in it and never touched the tranny.
Also, thinking about adding another 10,000 lbs tranny cooler to the X. I'll mount it out in front of the AC condenser and break the lines at the location where I change the tranny fluid.
I have a 10,000 lbs cooler on my T-Bird SC installed after the fluid goes through the radiator. My tranny temp gauge rarely goes above 140°F and that is only on a real hot day. Normally runs about 140°F or less in the summer and does not move in the winter.
DSMMH
__________________
04 EXCURSION LTD: 4X4, 6.0L PSD, JUICE w/Tude, Jobe Intake, Elbow Upgrade, ZOODAD, MBRP T-Back, Bilstiens, Hawks, Cryos, Prodigy, Remote Starter, Red OPTIMAs, 30MM Sway Bar, WAAG FB Guard, Dual Steering Stabilizers, Fuel Cross Over Line, PML Tranny Pan, Coolant Filter, 160 AMP Alt Upgrade and RP Synthetics.
With the F5 chip in stock mode and BTS trans with the 6.0 Cooler (no deep pan or anything else) I am making about 55 above ambient in summer
__________________
Here's something to watch out for. The 6.0L has 1/2 inch cooler lines. Don't install a cooler with smaller lines, it will be too restrictive. If there is restriction the rear of the trans won't get enough lube flow and you'll destroy it. Also, if there is restriction you'll end up with LESS cooling with the extra cooler.
I don't think there is hardware on the market that can improve the cooling on a 6.0L truck. My recommedation is to leave it stock.
__________________ Mark
Former Ford automatic transmission engineer, 1988-2007.
Maybe YOU can tell us this since you were in the inside. Why did the 7.3s get those wimpy coolers while the V10 got better coolers and the 6.0, got the best of all? I've always wanted to know what made the V10 get a larger cooler? Why did they go gonzo with the 6.0?
__________________
