All I will say about the V10/7.3L is that I think some person did a better job on the cooling system than his counterpart on the other package. I was not involved with either.
When the 6.0L was in development they decided that they were going to do this one right. It is the best cooling system that Ford has put on anything.
__________________ Mark
Former Ford automatic transmission engineer, 1988-2007.
Here's something to watch out for. The 6.0L has 1/2 inch cooler lines. Don't install a cooler with smaller lines, it will be too restrictive. If there is restriction the rear of the trans won't get enough lube flow and you'll destroy it. Also, if there is restriction you'll end up with LESS cooling with the extra cooler.
I don't think there is hardware on the market that can improve the cooling on a 6.0L truck. My recommedation is to leave it stock.
How often do you change the transmission fluid in your truck? thanks !
just remember, a trans that runs too cold is bad for it as well. leave it stock or just add to thestock 6.0 trans cooler. out of the stock cooler and into the 2nd cooler. and then back to the trans.
__________________
01 EXCURSION LIMITED, 4X4, V10, 22" CHROME WHEELS, LOTS OF CHROME, LOTS OF TVs, 06 FRONT END CONVERSION, LIGHT BAR WITH 6" HID LIGHTS
How could it run too cool? IIRC, there is a valve that stops the flow of fluid to the cooler should it be cold and allows flow when it is hot. Now if your valve were not functioning in winter, well, maybe.
__________________
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system and Van Turbo. Bilstein Shocks with U code front and A code Rear.
huh? valve?? oh ok. well, i do drive a v10 X, not a diesel. I didn't know that. In a regular situation i guess my statement is true then. well, i guess i would go ahead and get the 2nd cooler then. but only if my trans is was overheating by checking with an accurate gauge.
__________________
I wouldn't bother with the coolers unless you are talking about replacing the stock one with the 6.0 cooler
__________________
hmmm. really cool. oh, i just crawled under my X and holy crap, i have one too. and i have the v10. I never even figured..
__________________
