Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-09-2008, 05:02 PM
Bearkat50 is starting off with a positive reputation.
1964 Ford 390 missfiring problem
Hello to all, im new here and this is my first post, i just became the proud owner of an all original 1964 ford galaxie 500 and the engine and tranny it has are original just rebuilt, all works, has most if not all vaccums and a 4bbl stock carb..car looks colmpletly stock under the hood and it just started to idle like crap, i mean i have to have the pedal somewhat pressed down just so it wont turn off. the sparkplugs are new, the oil and filter are new, the water pump is new distributor and wires look good i cant figure it out, some help will be greatly appreciated thank you!
  #2 (permalink)
Old 05-09-2008, 06:19 PM
Redmanbob's Avatar
Humble servant of my Peni
Redmanbob is starting off with a positive reputation.
Well if it isnt as simple as an adjustment of the idle stop screw then,, I'm guessing you might have a vac leak. Vacuum Gauge would tell you if thats the case..or some carb cleaner spritzed around the base of carb and hoses (aztec method). Or could be alot of stuff really when you get right down to it, but hey you gotta start somewhere/
__________________
66 F100 352 V8
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/619321-russ-east-vs-west-3.html
  #3 (permalink)
Old 05-09-2008, 06:34 PM
Bear 45/70's Avatar
Bear 45/70 is gaining momentum as a positive member of FTE.Bear 45/70 is gaining momentum as a positive member of FTE.
Are the new plug wires on right, #1 on the dist. to the #1 plug etc? Just because the cap and wires look good means nothing, change them. Points and condenser need to be changed, check dwell and timing. Do you have the vacuum hoses on right or is one cracked or split. Fuel filter dirty? It should be on the fuel pump. How old is the gas? have you tried adjusting the carb? And it can go on and on from here.
__________________
Bear 45/70
Gimp Racing
Don't pick a fight with an old man. If he is too old to fight he will just kill you.
  #4 (permalink)
Old 05-10-2008, 11:33 AM
Hey you guys i just found out what the problem was, i removed the distributor cap and just scraped some residue off of the contact tab and now its working fine, runs cherry! i really appreciate the help fellas thanks!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
