Quote:
Originally Posted by bgalaxy67
So if you did hook up another sub to it, it would either change the ohm load to 1ohm of 4ohm
1ohm may be too low to run the amp. It would get hot quickly. Not saying it can't be done, but it comes with risk.
4ohm would have your amp running at half the power it is now, then you divide that by the number of subs.
yea I would rather not run 1ohm and 120rms each isnt enough so dont want to do 4ohms
I dont know what amp I can use now because ill either have to run 1ohm or 4.. the kicker 750.1 is 750rms at 2ohms and like 375 at 4...
I dont know what to do now. Right now im thinking another Kicker zx400.1 amp. I guess I would have to get a D block and and RCAs to wire them both together.
