choke puzzle - Ford Truck Enthusiasts Forums
choke puzzle
Old 05-09-2008, 05:33 PM
white stallion white stallion is offline
white stallion is starting off with a positive reputation.
choke puzzle
hi! I've been having a problem with my 05 f150 5.4 lariat 61k on it. when I hit about 45-50 mph the engine "chokes" or "putters" like sort of a "cough" or something, until i let go of the gas. Its happened to me a couple times, not every day and not again the same day. I took it to the dealer where they fixed I dont know what??? and never solved my problem, the next day it did worse so they said they cant diagnose unless the engine light goes off but i hate waiting for things to get worse. these guys acted like they've never heard of such a problem before. they changed some sensors did some timing thing, and said "that should do it" I'm under extended warranty 100k. I appreciate the help, thanks
Old 05-09-2008, 05:49 PM
mattd17's Avatar
mattd17 mattd17 is offline
mattd17 is starting off with a positive reputation.
when this occurs, is it while under a "load", or just slight throttle..... is it while the overdrive is on? it almost sounds like a bad COP. when it happens if you give it more throttle to downshift, will it still happen or clear up?
Old 05-09-2008, 06:20 PM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
there is a TSB for 05's with bad injectors. I think this or the COP is your most likely culprit.
keep us updated, wish I could help you more
Old 05-10-2008, 11:30 AM
fastball fastball is offline
fastball is starting off with a positive reputation.
choke puzzle
<HR>My 08 has 12000 kms on it and it does the same thing. Sometimes between 40-50 mph, the truck "putters/flutters" when under load. Then if I let go of the throttle or hammers on it it clears up. Also the CEL doesn't come on. I have no idea what the problem is but it is really starting to bug me. What is a COP?
Mike
Old 05-10-2008, 12:00 PM
VFR_Man's Avatar
VFR_Man VFR_Man is offline
VFR_Man is starting off with a positive reputation.
Coil On Plug or something to that effect.
Choke questions answered. fmc400 1973 - 1979 F-100 & Larger F-Series Trucks 55 07-30-2014 11:11 AM
starting issues loveless41908 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-13-2011 12:00 AM
Correct starting procedure inline 6 jazzmaffy 1961 - 1966 F-100 & Larger F-Series Trucks 9 06-19-2010 12:24 AM
<<<<Help 99 has fuel issues>>>> Dpd696 1999 - 2003 7.3L Power Stroke Diesel 12 04-18-2009 05:43 PM
Knock, knock... Mikeman Aerostar 6 04-21-2004 12:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
