I still am not getting a charge to my battery. I'M wondering if I hooked up the voltage regulator correctly to the altenator? I've replaced both tested the altenator tested the battery, hooked an ammeter up and it reads 0, battery reads about 12.6 running or not. I did my own wiring so im wondering where do all the connections go? Voltage regulator has I A S F ....can anyone tell me the correct way to wire each of these to my Ford 3G Altenator.
Thanks Dan
A Ford 3G does not use an old style external regulator. If you have the old style alternator that does require the regulator, here's how it's hooked up.
