Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-09-2008, 09:40 AM
Payner44's Avatar
Payner44 is starting off with a positive reputation.
Need a rear axle for my '66
Hey Guys, I am in need of a rear axle for my '66 F100 4WD. If anyone has one they're willing to sell or knows where I can find one, please let me know. Thanks!!
__________________
Luck is when preparation meets opportunity...
All visitors add joy to my home...some by coming...some by leaving.
1964 F100 Custom Cab w/292 - 4 speed
1966 F100 4x4 w/390 - 4 speed
1966 F250 CC Camper Special w/352 - 4 speed
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-09-2008, 09:50 AM
garbz2 is gaining momentum as a positive member of FTE.garbz2 is gaining momentum as a positive member of FTE.
Do you need a housing or just the axles?
Garbz
__________________
64 F100 "Christine" 472 EFI C6 and mean
63 F100 Uni Custom under construction 4" off the pavement and built to drive DOHC, EOD.
69 F250 Crew Hiboy 360 435. Driver.
05 Escape XLT
  #3 (permalink)
Old 05-09-2008, 09:52 AM
Payner44's Avatar
Just the axle...back left has a VERY slight wobble that I don't like to see...
__________________
  #4 (permalink)
Old 05-11-2008, 02:04 PM
Moser has new stock length axles in 28 spline. Reasonable too. Can order them complete with the bearings pressed on.
NAPA also usually has jobber axles available.
Are you sure it is the axle? and not a bent or out of line housing? or even a bad rim?
Did you run a end dial indicator to see how much out it is?
Bearing wear will allow a slight wobble. Might be as simple as changing retainer and bearing.
Garbz
__________________
05 Escape XLT
  #5 (permalink)
Old 05-11-2008, 02:22 PM
Payner44's Avatar
All I have done at this point is have a mechanic friend watch me drive away to determine the amount of wobble, because I don't feel anything when driving the truck. This all came about when I noticed the left rear wheel was leaning in slightly at the top when parked on level ground. We haven't had a chance to take the wheel off to investigate further. My friend just felt the axle was probably bent ever so slightly. We never discussed a worn bearing as a possible culprit, which sure would make the fix cheaper.
__________________
  #6 (permalink)
Old 05-11-2008, 02:25 PM
I would pull the axle. I had the same issue on my 64 a slight wobble i could not feel. Ended up spitting the bearing at the big ditch and had a 200 mile limp back to phoenix.
Just think Keystone Kops.....200 miles at thirty is a long haul...
Garbz
__________________
05 Escape XLT
  #7 (permalink)
Old 05-11-2008, 07:10 PM
hgene226's Avatar
hgene226 is starting off with a positive reputation.
I'll tell ya it is really simple to pull the axle and have a local shop replace the bearings. You may want to try this before changing out the rear end. Even I could handle it!
__________________
1965 F100 SB 352
  #8 (permalink)
Old 05-14-2008, 08:51 PM
ol yeller is starting off with a positive reputation.
I have 1 I'll give you for the shipping from FT Worth TX. Let me know
__________________
DAVE
  #9 (permalink)
Old 05-14-2008, 09:30 PM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant futureNumberDummy has a brilliant future
B7TZ-4234-A .. Axle Shaft
Fits: 9" / 1957/67 F100 / Right/left is the same.
__________________
Bill / Retired Ford Partsman ~ 1962/97
Part number research: Trucks 1948/02 / Cars 1949/91
1963 Galaxie 500XL / 1965 F100 Styleside / 2008 Fusion
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
