Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 6.4L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-09-2008, 05:29 AM
jhess is starting off with a positive reputation.
HHO Generator
This is a continuation from titan tank thread. As for the HHO generator it seems a first I'm 3-4 miles increase and that will get better with time. I still have hook-up the air pump. The air pump will increase production of the H2 at low load demaned on the engine. It will take time for this new technolology to be more know but, it looks good. If you are looking for MPG like me than this seems to be one of the ways to help with the problem.
I am also running the SCT livewire and is showing a increase also. Any thing that is going to stop that regen process is $ in my pocket. I'm try answer some questions or refer you to someone that does know. I'll also be reporting on my progress.
  #2 (permalink)
Old 05-09-2008, 10:43 AM
Momorris is starting off with a positive reputation.
How hard was the HHO generator install? How much were all the parts? I am interested in this.
Do you have any pics?
__________________
2005 F250 KR CC 6.0L
DashDAQ - soon to be Phalanx Monitor
ARP headstuds
Silverline Turboback
SCT X3...Spartan and Innovative tunes
DFuser Coolant Filter
  #3 (permalink)
Old 05-09-2008, 12:40 PM
Demolition is starting off with a positive reputation.
Just read about this on the MagDrive site. MagDrive Fuel From H2O - HHO Generators
Did you have this installed or did you do it yourself. Warranty at MagDrive is dependent on authorized install. Says Price for a "Double Brick" is $599 is that about the price you paid? And what the heck is a double brick vs a single brick?
This is interesting due to it being hydrogen technology combined with fossil fuel. Was not aware that you could run both together. I am very interested due to the claim of 35-45% MPG increase. Please keep us updated with pros and cons...
__________________
08 F250 KR PSD CC 4X4 Auto 3.73 SWB Line-X FS2500 Bypass Oil Filter, Viper 791XV w/remote start. Insight Multi Gauge Display. Retrax.
08 F350 KR PSD CC 4X4 SRW Auto 3.73 (Sold)
  #4 (permalink)
Old 05-09-2008, 01:05 PM
ALEXVB22's Avatar
ALEXVB22 is starting off with a positive reputation.
I have a 6.0 and I'm interested to.. I have been tring to build one of these (that puts out A LOT of HHO gas) for a while now.. Just Really afraid to put it on the truck. Any problem with it yet? jhess... Pics?
Alex
__________________
05' F-350, Kingranch, Crew, Dually...
SCT X3_ Coming really soon!
Afe XP Stage 2 Intake_ on its way today!
  #5 (permalink)
Old 05-09-2008, 01:39 PM
HHO instalation
I chose to put it on the truck myself they give you good instructions on how put this all together. I bought a double brick which is just two brick together, it gives you more production of H2. I'm now think of tring to make one of thees to increase H2 production even more. As for it being burnt with diesel fuel the engine don't care how it meets its demand in the combustion stroke, Liquid v. Gas both are flamable.
They claim after the combustion O2 & H2 condense back to water and then flash off to steam absorbing the heat in the cylinder giving you a cooler EGT. I spent $900 for a double brick
  #6 (permalink)
Old 05-09-2008, 02:02 PM
ALEXVB22's Avatar
Could you post some pics?
If you do a search on Bob Boyce's 101 HHO generation cell design you can find many many plans on how to make it.
It's said w/ his design you can get out about 60LPM of gas generation... That's a heck of a lot more then I have been able to get with some of these sites DIY designs...
I got to about 4-5 lpm with a set of basic 304 SS pipes, weld-rod, a bucket, and a tube to run the HHO gas to a Bottle upside down in a bucket ful of water...
Any clue to as how much HHO gas you generating w/ that set up?
I'm very per-plexed to see that its actually working... Do you have guages that can verifiy that your actually lowering your EGT's?
My Biggest concern was getting past the EFIE system (but I dont know too much about diesels... learning though) Originally, I thought that if and when you added HHO gas to the intake the ECU reads it as too much oxygen and the Computer would through more fuel at it to get the air/fuel ratios right again... Thus eliminating the advantage of HHO...
- But after asking in another thread I was told that Diesel don't run on a set Air/ Fuel ratio and that the ratios are rather "all over the charts". I don't fully understand this, Could you explain?
Because if this is true, then no matter how much HHO we through at it, it should work... And timing should not matter when its used as a supplement considering it won't ignite until the diesel has because it has a much higher flash point.
Are any electronic devices used to trick the PC of the truck?
Alex
__________________
  #7 (permalink)
Old 05-09-2008, 03:29 PM
Alex, check out the magdrive link in demolitions post. It is very informative on this works.
Also, air/fuel ratios dont matter on diesels. That is why we dont have throttle bodies. From what I understand, boost and power are regulated strictly by fuel and timing. According to that website, todays computers can handle all the calculations of the HHO system.
__________________
ARP headstuds
  #8 (permalink)
Old 05-09-2008, 04:10 PM
kimminau2 is starting off with a positive reputation.
Please keep us posted on how it works out, it is interesting if it works.
__________________
2008 F450 King Ranch, 4.88's and everything except rear DVD.
2006 F250 King Ranch V-10, 4.56 gears, 46 gal transferflow tank, 2-1/2" DR lift, 35" Procomp extreme AT tires, SCT tuner, Firestone Ride-Rite air bags.
2000 Excursion 4x4 V-10
2007 Expedition EL, Eddie Bauer, loaded.
  #9 (permalink)
Old 05-09-2008, 06:26 PM
kawtiper is starting off with a positive reputation.
so did you get the Series 12a Micro-processor Dual Brick HHO gen
this is so exciting I think I just wet my self
__________________
08 6.4 3.73 4x4 20"wheels tow package air bags and not so bad mileage
  #10 (permalink)
Old 05-10-2008, 05:34 AM
12A double brick
Yea, that the one I got (12a with the air pump) Jim, at Megdrive claims the air pump will help with production on city driving also. That will increase you MPG total.
  #11 (permalink)
Old 05-10-2008, 01:59 PM
bookem15 is starting off with a positive reputation.
nothing from me just subscribing to thread. This does sound very interesting.
__________________
Drive it like ya stole it !!!
1997 F150 xtra cab 3 door 4X4 104,000
next truck
really really WANT F350 Harley edition
6.4 psd CC LB w/all the goodies
but
F150 with the diesel and the goodies
is all I really NEED!!
  #12 (permalink)
Old 05-10-2008, 02:15 PM
Is yours the model with the microprocessor? What engine are you running, 6.4 I assume. Can we get some pictures soon, please.
Thanks, I think you have a lot of FTE'ers intrigued, I know I am.
__________________
ARP headstuds
  #13 (permalink)
Old 05-10-2008, 03:24 PM
microprocessor
Yes, I am using on a 6.4 and I have the one with a microprocessor.
I had some a work today and cut some stainless steel to make a 3 1/2sq/ft total generator to add to my system. When I get all done I'll to slow down enoght to take some pics, right now I only have time to get on the computer at work. I'm a dummy, LOL I got all the ideas from searchs on You Tube and watching the videos of other people. Thats how I learned about waste oil converstion.
  #14 (permalink)
Old 05-12-2008, 08:57 PM
horstman1970 is starting off with a positive reputation.
People...another name for an on-board closed loop HHO generator is a "dynamic brake". One that, if activiated, causes your car to stop in much less than its normal coasting distance.
The HHO generator and all it's internet hype is nothing more and an reincrapnation of "Brown's gas"
On-board electrolysis to generate H2 from water will NEVER improve fuel efficiency...its not possible now nor will it ever be...can't work....won't work....no conspiriacy...just the facts
  #15 (permalink)
Old 05-12-2008, 11:21 PM
versitek is starting off with a positive reputation.
Please explain why this will never work and how does it differ form lets say propane or any other gas? Thanks for any info.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
