Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 6.4L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #16 (permalink)
Old 05-13-2008, 12:06 PM
horstman1970 is starting off with a positive reputation.
Just the facts
I'll explain; fficeffice" /> > >
2nd law of thermodynamics states that in a closed system enthalpy always decreases and entropy always increases. Simply put; unusable energy (entropy) always increases, useable energy (enthalpy) always decreases. > >
In the case of an HHO generator...making H2 and O2 from H2O. While this can easily be done it is not efficient because of the second law of thermodynamics. Simply put; H2O is a product of an exothermic reaction. A fuel (hydrocarbon or just H2) is reacted with an oxidizer (O2, air or other chemical oxidizer). This reaction gives off energy (heat) and the byproduct (ash) is water. Think of it this way, hydrocarbons, LPG, H2 or whatever are not by definition an energy source but rather an energy carrying medium. > >
How does HHO differ from other gases like propane? Well propane already carries the energy. This energy was stored in the form of propane deep inside the earth under heat and pressure. The HHO generator would be the same as taking CO2 (or other source of carbon) and H2O and converting them into propane. It takes more energy to do this than is released in an exothermic reaction back to CO2 and H2O.....2nd law of thermodynamics. > >
The only conceivable improvement in efficiency using the HHO generator is that it is not producing any significant amount of H2 and O2 but rather because it gets sucked into the engine through a vacuum the water is really boiling and water vapor is what is actually going into the engine. Water injection USED to be used in gas turbine engines (my area of expertise) to increase horsepower and efficiency...but it was quickly learned that it was not cost effective due to the cost of the system and the degradation of engine parts. Also this increase in horsepower and efficiency could be measured in a turbine engine producing 30,000 to 100,000 base hp and consuming many thousand of dollars of fuel per day....in you 350hp engine doubtful any meaningful measurement could be made.
Another name for these HHO generator salesman is Liar, cheater, thief, take your pick. > >
  #17 (permalink)
Old 05-14-2008, 08:11 PM
big kahuna is starting off with a positive reputation.
horstman1970 is totaly correct .I am not as knowledgable in that area but I do deal with chemicaly induced exothermic and indothermic reactions and the laws of physics.
  #18 (permalink)
Old 06-11-2008, 05:31 PM
dougphysics is starting off with a positive reputation.
More on how this is internet hype
The idea of the HHO kit is to use a little bit of electricity that is made by the engine (by the alternator) and create HHO gas which more than makes up for that electricity you used. Why bother putting this in a car.... just hook it up to itself. It should be able to make free energy essentially. Use a little bit of electricity to make the HHO gas and then run an engine that makes lots of extra power.
"Free energy" has been proved impossible over the last 200 years and you can only find people with no science background selling them. They never work in any lab test. The inventor never powers his house off it, or hooks it up to the grid to produce power and make money. Sure sounds great, but if this was true, there would be free energy, and making your car more efficient would be the least amazing thing HHO offers.
Scientists can't even confirm HHO gas exists! I mean come on, they invent new elements in the lab, you would think the least they could do is find HHO gas that a layman can make with a kit for a couple hundred bucks. So obviously it's just making H2 and O2, wow century old technology.
Now a good idea is to hook up a normal electrolysis gadget and make some pure Oxygen and pump that into the engine. Now you can pump in more fuel and get more power. It's like a nitrous boost. That sure won't help your gas mileage tho.
  #19 (permalink)
Old 07-05-2008, 08:34 PM
dvildg is starting off with a positive reputation.
Hey,
Fairly new to post but have been researching this HHO stuff. Granted, I understand the zero energy argument, but we aren't burning pure HH0 (also known as Hydroxy, and H2 02 gasses). This product that you make on demand is basically a fuel additive, that helps burn more completely the given carbon based fuel of choice, gasoline, deisel, etc. No different than any of the commercially available fuel additives that supossedly increase mileage.
Drive a little slower, don't stomp on the go juice at lights and you should get better mileage..I did just that and have a slight mileage increase between fill ups. You can build basic systems for under 100 dollars, most of us throw that much away with piss poor driving habits.
Once upon a time the world was believed to be flat, yet Columbus didn't let the nay sayers sway him from trying. If it doesn't work, no harm done, but at least you tryied to squeeze some extra mileage out and that can't be a bad thing...Peace
  #20 (permalink)
Old 07-05-2008, 09:24 PM
Hydroxy?
Perhaps you meant Oxyhydrogen, but that is a mix of O2 and H2. Again, there is no such thing as HHO. Santilli proposed magnecules to exist, HHO being one of them, but no one has ever seen an HHO molecule, and Santilli is regarded as a proponent of false theories. Let's call it Hydrogen and Oxygen, so at least we are in the realm of reality.
Here is a link to proper scientific studies of adding Hydrogen to different engines. Granted, in Diesel engines it does help completely burn the mixture, but as stated in the article, it is highly unlikely that it is possible to increase fuel efficiency if you are generating the hydrogen from water. It has never been demonstrated in a lab. I am sure that the folks at the Jet Propulsion Laboratory had much more money and expertise and did not even bother trying this for obvious reasons, it won't work.
Adding hydrogen is very effective in reducing emissions and is the most useful application for this technology. There is a government evaluation program for any product that can aid fuel economy for cars or trucks that will give you millions of dollars if you can prove it works, however there is no product using "HHO" gas that has even applied for this. Why would they turn down money, unless it's a scam.
Wow, driving slower gives you better mpg?!?! Who would have thought.
All the major car companies invest billions of dollars into improving fuel efficiency, which helps them sell their cars over their competitors. Don't you think they would add cheap products like these if they worked.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
