Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-08-2008, 06:35 PM
MCGA is starting off with a positive reputation.
Help please!!!!!!!
I have a 2003 Expedition. My extended warranty will be running out the end of June, so need this figured out! My dealership can't get this right.
Problem: Door locks are not working. Started with the rear passenger door. Took it to dealership and the replaced the actuator. When I picked it up, still didn't work. It would work sometimes and then it would not. Same problem with door button or using key remote. Problem then progressed to other door locks. They then replaced whatever it was that caused a new code to be used in the key-less entry. Problem solved for 3 weeks, and now the rear passenger door lock is acting up!
Also at the same time the engine started to run real rough. When at idle it would almost stall out! They replaced the O2 sensor and the throttle control air valve. This was done at the same time as above was replaced. Now that the rear door lock is acting up again, the engine is starting to idle funny again. Can this be caused by the same problem. Computer chip? It is worse when the A/C runs. Also, there is a noticeable whining noise when the compressor of the A/C runs. This is new. Can it all be the same issue or are they all just perfect timing? I know this is a rambling post, but I hope someone can help, my wife is looking to me for the answers!
Please ask any questions that may help to clear this up. In summary: door locks are randomly locking with no pattern noticeable. Rough idle and compressor seems to be whining very loud!
Any help greatly appreciated!!!!!!
  #2 (permalink)
Old 05-08-2008, 07:03 PM
ReAX's Avatar
ReAX is gaining momentum as a positive member of FTE.
The VSM controls the door locks, the PCM controls the engine. They do communicate, but I can't think of any thing connecting them that could connect them and fail. I'd look further up the food chain, battery connections and chassis grounds, your General electronics module should be in the cluster, but ford should have had trouble communicating with other systems if it failed. You may just have two problems, ie a bad coil causing the idle problem plus a ground problem affecting the VSM.
If you figure it out, I'd love to know. I have a similar issue that I haven't been able to fix. So far I have replaced the VSM, Cluster and the door closed sensors.
__________________
Too many mods to list, so click here.
-MECP 06/27/08
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
there's a very fine line between not listening, and not caring. I like to think that I walk that line every day of my life.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
