Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-08-2008, 05:49 PM
stev3-o is starting off with a positive reputation.
Tranny Delay when shifting to Drive
Yesterday i noticed when i was going into reverse, then went into drive, it would take 3-5 seconds to engage in drive. its a 2006 f250 only 18k miles. can it be a bad issue??
  #2 (permalink)
Old 05-08-2008, 06:05 PM
toolman05kr is starting off with a positive reputation.
Check your fluid level, if it's low this could happen, also were you parked on a hill? if so you could have run short on fluid. welcome to FTE, alot of great info and great people here.
__________________
ASE Master Auto/Medium and HD truck Tech. Master Auto Electrician.
  #3 (permalink)
Old 05-08-2008, 06:07 PM
heavyiron is starting off with a positive reputation.
Mine does the same thing, has since new.
__________________
07 Ford F250 CC SB 4WD FX4
"Talent is God given, Be Humble. Fame is man-given, Be Grateful. Conceit is self-given, Be Careful."
John Wooden
  #4 (permalink)
Old 05-08-2008, 06:43 PM
fluids are all perfect, i bought the car used 2 weeks ago at Greenwood Chevrolet, checked the fluid everything topped off. was gonna take it in and get it checked out but according to everyone i should bother since they probably wont do anything since there arent any codes.
  #5 (permalink)
Old 05-08-2008, 07:55 PM
liv liv is offline
liv is starting off with a positive reputation.
I've noticed it in every 6.0
__________________
-03 F250 FX4 Lariat Crew Cab, 6.0, Edge with attitude, turboback 4" MBRP with 8" tip, AFE CAI, 6" Fabtech lift, 35" Nitto Terra Grapplers, 18x12.5" Weld Cheyenne wheels, Autometer Pro-Comp Boost and Pyro, Westin Bull Bar, B&W Gooseneck Hitch
-35' Load Pro Flatbed Gooseneck
-17' Bass Tracker Pro17
  #6 (permalink)
Old 05-09-2008, 02:46 AM
bismic's Avatar
bismic has a good reputation on FTE.bismic has a good reputation on FTE.bismic has a good reputation on FTE.
Quote:
Interesting, mine does not do this.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #7 (permalink)
Old 05-09-2008, 07:39 AM
69cj is starting off with a positive reputation.
Try mine Liv! It doesn't do it.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
  #8 (permalink)
Old 05-09-2008, 03:29 PM
Z-MAN is starting off with a positive reputation.
Delay In R And D Could Be Shift Selinoids Picking Up Clutch Pack Material Delaying Engagement, I Would Check External Trany Filter For Clutch Plate Material If So Its Time For A Tranny Flush And Filter Change Dont Forget The One In The Pan Too.. Any Codes? Not To Many Miles On It, It Might Be A Simple Fix.if That Doesn't Help Your Issue, Bad News, It Didnt Clear Mine Up At 74,000mi And It Was Rebuild Time.. Good Luck Hope This Helps
__________________
2003 CC/SB SRW BLK 6.0 LARIAT FX4 4X4 SIX-GUN BUNDLE/W SPEED-LOADER, SCT3 W/SPARTAN TUNES,TRIPLE GAUGE A-PILLAR , PML TRANS PAN.ARP HEADSTUDS.
  #9 (permalink)
Old 05-16-2008, 08:41 PM
liv liv is offline
Quote:
Sorry to bump
I've never driven one that wasn't a work truck (except mine, which also does it, except its basically my personal loader hauler =D) so maybe that has something to do with it?
It feels much more like a safety than a mechanical problem. I don't do too many 30 mph reverse to drive 180 spins so I guess it doesn't really bother me
__________________
  #10 (permalink)
Old 05-17-2008, 06:54 AM
No flame intended but the Edge has been associated with tranny problems.
__________________
"71 Triumph Trident
  #11 (permalink)
Old 05-17-2008, 09:58 AM
bismic's Avatar
Quote:
I see that you bought this truck from a Chevy place (previous post). Are you sure that they put Mercon SP in it? This is a requirement for proper functioning of the tranny.
__________________
Mark
  #12 (permalink)
Old 05-17-2008, 07:02 PM
sandmanf250 is starting off with a positive reputation.
tranny delay
my 03 6.0 f-250 has done that since new and has 126k on it.
  #13 (permalink)
Old 05-17-2008, 07:14 PM
bismic's Avatar
I would definitely take a truck back to dealership for warranty repairs if it did what you guys are describing when new.
They should definitely not do that ...... 3 to 5 seconds ?? - terrible!!! I have had a 2005 F250, now have a 2006, also know at least a dozen people w/ them and none have done this.
__________________
Mark
  #14 (permalink)
Old 05-17-2008, 07:52 PM
doubledee715's Avatar
doubledee715 is starting off with a positive reputation.
Quote:
he actually didn't pick that one up, pretty sure he got it from a ford dealership
__________________
David, 2003 f250 6.0 cc sb Centennial Edition, Dieselsite coolant filter, afe stage 2 w/pg7, ejf1000 edge juice w/attitude replaced w/innovative tuned xcal, blocked off egr cooler, Quadzilla Commander w/pillar mount, ARP studs, ITP RR, 05 accufab elbow, 4" tb, pic
  #15 (permalink)
Old 05-18-2008, 11:14 AM
liv liv is offline
Reading back that is a bit much. I would say maybe 2-3 seconds is what I've noticed
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
