Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-08-2008, 03:41 PM
gvrangr98 is starting off with a positive reputation.
Exclamation Ignition coil...install...
Has anyone ever installed an ignition coil on a 69 Bronco? I think the motor is from a 1973. The motor is a 302. after i install the coil it should start up..or at least turn over, right? If it doesn't what do i look at next?...the starter solenoid and starer?
Come on guys...come through for me1
__________________
1998 Ford Ranger XLT 4X4 KingCab Stepside
Vulcan V6 3.0 Automatic
Customized K&N Cold Intake
Customized 2.5 in. CatBack by "Lou's Custom Exhaust"
245/70r16 BFG OpenTrail T/A's
213,565 "New England" miles and climbing
1994 Saturn SC1
249,478 "New England" miles and running strong!
38 MPG (Daily)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 05-08-2008, 05:25 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
There is nothing special about installing a coil. Just unbolt the bracket, undo the wires. Remove the bracket from the coil and install the new one. Make sure that the wire going to the distributor is attached to the - side of the coil.
The coil will not make the engine turn over. It only supplies spark to the dist secondary (plug wires).
If the engine won't turn over, have you tried to turn it over by hand at the crankshaft? If not, you may have some other issues to deal with.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #3 (permalink)
Old 05-17-2008, 08:00 PM
EricJ is starting off with a positive reputation.
Need more info.
did you check battery voltage?
what happens when you turn the key? click? nothing? chatter?
do you own a volt meter or a test light?
  #4 (permalink)
Old 05-17-2008, 08:43 PM
nope. I don't have any of that stuff. all i know is when i turn the key i get nothing natta zilch! the battery is not the problem, i'm sure. i need to test the line from the bat to the ignition coil, to the starter solenoid to the starter. and the starter and starter solenoid also need testing themselves. I don't really know if any of those really work.
  #5 (permalink)
Old 05-18-2008, 04:31 PM
YOu need to get either a volt meter or a 12volt test light and I can talk you threw checing it out. It's actually a simple system.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
